Again, they do not state they are OEM DJI props. Maybe ask the seller if they are OEM before you buy them.Alright, what about these from the US?
All of the props are 8330F. You'll see them labeled near the hub.Also, I think the 8330 are the White ring propellers and the 8330F are the black ring or vice versa?
I bought them just to check them out. Here's what I can tell you about them:has anyone purchased the AerialTEK propellers? any advantages?
Also, I think the 8330 are the White ring propellers and the 8330F are the black ring or vice versa??
I just ordered a set from dji. $9 plus $10 shipping to US. I feel safer with oem than the ebay ones at half price.
- They are not made of carbon fiber
- The material used seems to be the same/close to the OEM DJI props
- The surface of the props is not as smooth
- The edges of the prop are a little rougher
- The props flex a lot easier/more than OEM DJI props
Yes. Each set contains one of each prop. You'll need to buy two sets if you want to replace all of the props.So when you buy the extra props from Dji THey send you one black and one silver version?
That's what I thought. When I ordered mine I ordered 2 sets.Yes. Each set contains one of each prop. You'll need to buy two sets if you want to replace all of the props.
They look like OEM DJI props, but nothing in the description states they are OEM. Everything just states they are "compatible". For that reason, I personally would not buy them.
I use a special "non-nutritive cereal varnish" on mine. Thanks to Clark G.But they state "Special clear coat aerodynamic coating to fly with less resistance"... LOL... what BS!
Sent from my SM-T713 using MavicPilots mobile app
