Adobe Premiere Pro fix magenta purple
dv8ed
Anyone know what needs to be done to fix purple magenta in trees and bushes?
I think they're supposed to be brown or gray.
Tried so many sliders usually makes everything else worse.
I googled a little people were saying since DJI uses Sony sensors this happens quite a bit.
Trees usually appear in mid tones. Take the mid tone color wheel and pull it opposite of magenta (toward green). Go slow as a little goes a long way. May need to tweak shadows some too. Finally you sometimes will need to make the opposite adjustment in highlights to balance it out.
With RAW images you see the same thing but in Lightroom there's a slider to desaturate just purple slightly.
I haven't found anything in Premiere better than one of the wheel tools used as above
thx I'll give it another try.
this is good info I use Lightroom for pics too.
kmikebennett
