*Not really. Don't know why this showed up on my iPad using Litchi app. Mavic is safely on my kitchen table. Just wanted to share
Need someone that lives in a desert to try this.What if:....You set a mission for say 50 miles, set Smart RTH, would it auto test your range?
(maybe I should start a new thread)
I would think smart RTH would work in that case. The Mavic will travel as far as it can keeping in mind how much battery is needed to get back to home. This would really be testing the range of the battery and not the aircraft/signal though. Also, as others have said smart RTH is a rough estimate and you could end up with a forced landing before it gets home (at critical battery level). Keep in mind that RTH is supposed to be a backup in an emergency so it is not meant for normal use and your mileage may vary.
