Update to issue...
Went flying last night prior to fliying
When I restarted everything at the end, I noticed a new warning saying that my 6P WiFi was causing interference with controller...
- Updated firmware to latest version
I did two thins last night
I flattened two batteries and did not have a single issue on either of them.
- I turned off WiFi when I went flying
- I used the short USB to C (I got with my 6P) cable and connected to the bottom of the controller.
I will try the Micro to C on my next flight
Here is hoping...
Hi
Just got back from a few great flights... ( 2 batteries)
I used DJI Go4
I enabled flight mode on my 6P
I used the Micro USB to C (cable that came with controller)
The disconnect did not happen again
I did have a few Go4 app crashes, this was while I was playing with follow me and the camera. I was able to maintain control of the drone at all times. ( I was 100% flying line of sight)
My conclusion so far is that it was a WiFi issue on the 6P that could have caused the problem.
I don't see this as to much of a problem as it helps save battery life anyway
I hope this helps...
Cheers
Hi, Yes it seems to be working...Hi,
Just wondering if your fix is still stable or...?
