Cyberpower678
- Joined
- Jan 11, 2017
- Messages
- 3,881
- Reactions
- 1,782
Hi , I'm unable to copy or save the dat files from the memory card , even if I go into **** utility and create new image it isn't allowing me to??
The noise on the back compass is caused by Sport mode, full elevator and the high current in wires to the back motors. This Mavic probably needs to have the fix being discussed in this thread.@BudWalker I think I've analyzed what I could. If you find anything I missed, let me know.
Re the obstacle avoidance issue I just couldn't resist the eye candy where you can see the Mavic braking, sidestepping and ascending to get around the "obstacles".
Sure, if you post another Dropbox link to a .DAT from one of the post-fix flights then @Cyberpower678 or I will take a look.so this morning I decided to open her up, twist the wires for the back legs and take her out for a spin.
No compass errors on screen and only once did the phone lose signal(dodgy lead i think).
Would one of you pls be able to look at the .dat data to see if the mod has improved the interference to the back compass. I'm sure it has but it would be nice to see the data on a chart. I will post the flight details below.
uploading now...400mb zzzzSure, if you post another Dropbox link to a .DAT from one of the post-fix flights then @Cyberpower678 or I will take a look.
These files are hug, but when your software converts them, it's radically smaller. What's it leaving out?just
You can analyze flight data with it, if you understand what it's reading out.What is that awesome tool? You wrote that application, correct?
i can convert it to an csv but i didn't think that contained all the data?What is that awesome tool? You wrote that application, correct?
The simple answer is that CsvView/DatCon is leaving out almost everything. It's even worse when you consider that the .DAT is binary and the .csv is a text file with a lot of white space. CsvView/DatCon is the result of having reverse engineered the .DAT file. The stuff you see in the .csv reflects what's been reverse engineered.These files are hug, but when your software converts them, it's radically smaller. What's it leaving out?
I'd be curious to know what information it is leaving out. That's a **** ton of detail.The simple answer is that CsvView/DatCon is leaving out almost everything. It's even worse when you consider that the .DAT is binary and the .csv is a text file with a lot of white space. CsvView/DatCon is the result of having reverse engineered the .DAT file. The stuff you see in the .csv reflects what's been reverse engineered.
I'd be curious too. I've seen a lot of stuff that looks to me like it is probably intermediate results of calculations.I'd be curious to know what information it is leaving out. That's a **** ton of detail.
Yes, go here to obtain CsvView.What is that awesome tool? You wrote that application, correct?
If there is a wind analysis in there, see if you can extract. Wind analysis is fun.I'd be curious too. I've seen a lot of stuff that looks to me like it is probably intermediate results of calculations.
here's a link to the dat file /twisted rear motor wiresSure, if you post another Dropbox link to a .DAT from one of the post-fix flights then @Cyberpower678 or I will take a look.
Downloading...here's a link to the dat file
Dropbox - FLY185.DAT
