Any ideas on how we could land the mavic on water?
Discussion in 'General Discussions' started by puravidastyles, Nov 1, 2016.
  1. puravidastyles
    puravidastyles Well-Known Member
    Oct 15, 2016
    67
    9
    So i am captain of a yacht.. and will no doubt be flying it a lot offshore, yeah i know its risky but its going to happen..
    Just wondering if we could put our heads together and come up with a solution....while we wait for them to arrive
    Totally get that i should not land it on water but also dont want to lose it, if for some reason it has to land on water..some sort of failure, return to home etc
    I am not talking about getting the thing water tight but just floatable landing gear to keep the said devise floating until help arrives..
    Any thoughts?
    drone lands on water - Buscar con Google
    Willem likes this.
  2. msinger
    msinger Well-Known Member
    Approved Vendor
    Oct 12, 2016
    5,144
    2,218
    Harrisburg, PA
    I think the Mavic is going to be too small to carry some type of flotation device. With a Phantom, you could use something like the Water Strider.
  3. puravidastyles
    Oct 15, 2016
    67
    9
    Looks too big and bulky. thinking more along the lines of just being able to land and not drown, rather than be able to take off...which would of course be a bonus but not if it impairs the flight in any way.
  4. msinger
    Approved Vendor
    Oct 12, 2016
    5,144
    2,218
    Harrisburg, PA
    Yes, it is definitely big and bulky. That's the kind of device you'll need to stay afloat though ;)
    puravidastyles likes this.
  5. kmaluo
    kmaluo Well-Known Member
    Oct 14, 2016
    423
    121
    If someone could figure out how to attach the white pieces under each motor mount, we may be in business.
  6. Butterpuff 6
    Butterpuff 6 Well-Known Member
    Oct 16, 2016
    156
    92
    Charlotte, North Carolina
  7. HeliFreak
    HeliFreak Well-Known Member
    Oct 12, 2016
    209
    42
    ^ what's that saying. "Drops mic...." LOL
    There you go....
  8. John Locke
    John Locke Well-Known Member
    Oct 13, 2016
    93
    51
    First, you need a display device with GPS so you have the ability to reset the home point. That's first thing you must have as a newbie flyer.
    Second, learn to fly. Once you become competent enough to hand catch you can easily fly at sea and return to home with no flotation backup. Learn to hand launch too, using a radio neck harness. However I'm unsure if the Mavic radio supports a neck harness like P4.
    Third, accept the fact if you screw up, or a system fails, you lose $1000 system. That's the price of sea operations, and this demonstrates the need to learn how to fly first and learn all of the things that can go wrong while flying. Understanding RTH, low battery auto landing, power management, and using the navigation tools in the Go app.
    If you want a solution that's more dummy proof, buy a waterproof drone and suffer with poor video, and inconvenience of awkward battery replacement. Those kind of drones are out there, available. Or, use a Phantom4 as mSinger suggested with flotation devices for $140. That's your best option if you insist on sea operations with failsafe. However, unless the sea is very calm I'm skeptical those flotation feet will truly keep the Phantom 100% dry if it landed on water. The sea gets rough.
  9. mikesher
    mikesher Well-Known Member
    Oct 26, 2016
    110
    23
    I personally hand catch my P3P from my yacht (sailing vessel) 100% of the time, and sometimes have a guest/crew assist with hand launch. The Mavic is going to be a bit more challenging.
  10. msinger
    Approved Vendor
    Oct 12, 2016
    5,144
    2,218
    Harrisburg, PA
    Hand catching should be doable if your Mavic is hovering steadily in the air. However, it could be a challenge if it's windy (or wavy in your case). When you grab the Mavic just right, your hands will be about 2-3 inches away from the props.
  11. Willem
    Willem Active Member
    Oct 24, 2016
    33
    14
    probably wouldn't be too hard to attach the getterback to the mavic (How It Works) btw - i've flown at least 50 trips with the phantom 4 from my boat doing a hand catch and hand land - super easy. hand catching and landing from a boat is a major concern for me as well. I'm actually not too worried about it going into the sea so long as you respect your battery life, etc. if its anything like the phantom 4 - then I've done hundreds of flights over water without a problem
    boxsterfahrer likes this.
  12. msinger
    Approved Vendor
    Oct 12, 2016
    5,144
    2,218
    Harrisburg, PA
    The only problem with the GetterBack is that it will only allow the Mavic to be retrieved in up to 100 feet of water and the Mavic will still sink like a rock (which would be fatal in salt water).
  13. edison
    edison Well-Known Member
    Oct 15, 2016
    52
    15
    London
    DUDE. That is genius.
  14. bschaub
    bschaub Member
    Oct 15, 2016
    15
    7
    Learn to fly and land on the deck. No problem. I have always been very apprehensive about hand recovery. And, I really know how to fly with Phantoms, 250 class racers and fixed wing. No way I will ever get my face and hands that close to these props. Your milage may vary.
    mikeroycollins likes this.
  15. telecam
    telecam Active Member
    Oct 25, 2016
    29
    18
    I do that all the time too but how is that gonna work with the Mavic obstacle avoidance sensors?? Can they be disabled?
    mikesher likes this.
  16. msinger
    Approved Vendor
    Oct 12, 2016
    5,144
    2,218
    Harrisburg, PA
    You can still catch it with the sensors enabled. You'll have to reach up and grab it quickly though. Otherwise, the Mavic will start drifting away from your hand.
  17. mikesher
    Oct 26, 2016
    110
    23
    I have seen some videos showing hand catches, but not sure if the sensors were disabled. It looks like you have to grab it from the front, just under the front sensors. Anyone with experience? Please share.
  18. msinger
    Approved Vendor
    Oct 12, 2016
    5,144
    2,218
    Harrisburg, PA
    As I noted above, you need to grab it quickly. Otherwise, the Mavic will drift away from your hand. Here's an example showing that:
  19. mikesher
    Oct 26, 2016
    110
    23
    I do launch from the foredeck of my sailboat, but landing on the deck, is too risky IMHO. Too many obstacles: mast, shrouds, sheets, forestay, backstay in the way. I always hand catch from the stern, and bring in my P3P slowly towards me until I can catch it. As I mentioned earlier... the Mavic is going to be more of a challenge.
  20. mikesher
    Oct 26, 2016
    110
    23
    Note, he grabbed it from the rear (quickly).
Loading...
Similar Threads - ideas land mavic Forum Date
Any ideas what's causing this Mavic Pro Help Apr 21, 2017
Ideas for bike mount for mavics RC? Mavic Pro Discussions Mar 25, 2017
Attacked by birds! Any ideas on how to avoid.SO Mavic Pro Discussions Mar 24, 2017
ok new guy on block with ideas General Discussions Mar 23, 2017
mavic won't connect to my S7 Samsung any ideas? General Discussions Mar 4, 2017
Share This Page
