Battery LED issue.
Discussion in 'Mavic Pro Help' started by TheLightSpeed!, Nov 23, 2016.
  1. TheLightSpeed!
    TheLightSpeed! Well-Known Member
    Oct 12, 2016
    707
    317
    So I noticed today that my batteries started charging to a 100% and then standing with all four LED's on?
    I could have swore that before, it would charge to 100% and then would shut off?
    Now it finishes charging and all four leds stay on until I unplug it?
    Ideas?
    I've searched the manual for both the Mavic and the batteries with no luck?
  2. TheLightSpeed!
    Oct 12, 2016
    707
    317
  3. gregw
    gregw Well-Known Member
    Oct 16, 2016
    187
    108
    I believe that the last phase of charging is what you are seeing when the 4 LEDs are lit. i.e. battery is 99% charged, and it's being "topped off" for that last 1%... This last phase can take quite long to finish due to the low current.. When it is fully charge, the LEDs will turn off.
  4. NH Phantom
    NH Phantom Well-Known Member
    Oct 15, 2016
    62
    2
    I noticed this on one of my batteries also. all lights on next morning also
  5. generaltso
    generaltso Well-Known Member
    Oct 12, 2016
    245
    55
    Vermont, USA
    Is this with the charging hub or without? I've only ever charged with the charging hub, and the lights always turn off after charging.
  6. TheLightSpeed!
    Oct 12, 2016
    707
    317
    Without. In fact it only did it that one time. I can't get it to do it again.
    It was weird
  7. sebastianschneiderc
    sebastianschneiderc Active Member
    Oct 19, 2016
    25
    3
    I just saw the same thing with one of my batteries. One of them charges perfectly fine and after its done charging it turns off the leds, but the other one it keeps with the 4 green leds turned on after more than 5 hours of charging and if I disconnect it then I have to turn the battery off so the led lights turn off (I always charge them turned off as it's supposed to be, and no one has turned it on while charging). Any ideas or updates?
  8. ant104
    ant104 New Member
    Feb 25, 2017
    4
    I have a battery that when I plug it in to charge that the first led will start flashing and that is it... no progress led's at all. Any suggestions.
    I did fly the battery until it was really low....
Loading...
Similar Threads - Battery LED issue Forum Date
Battery charging - no leds :( Mavic Pro Help Yesterday at 8:31 AM
Top LED on battery flashing Mavic Pro Discussions Jun 18, 2017
Blinking battery LED Mavic Pro Help Apr 29, 2017
No RED LED on Mavic @ Low Battery Mavic Pro Discussions Apr 16, 2017
Battery led stays on after fully charged General Discussions Apr 15, 2017
Share This Page
