Bought used Mavic, can I extract flight data from it?
combustication
Hi,
I bought a used Mavic and want to see if I can extrac flight data off it. I plug it into my laptop and no drive shows up. Can I extract flight data from the drone?
Getting home I notice 1 of the extra blades had the nubs torn off and I want to see if it's been in a crash of some sort, would files within the drone indicate what happened?
Thanks.
You can export the internal DAT flight logs from the Mavic using the DJI Assistant 2 app. The problem is there aren't any apps that can read those DAT flight logs.
Reactions: combustication
Yes.
The author of DatCon (@BudWalker) is working on a version that can read Mavic Pro DAT logs. I don't know how far along he is though.
You can use the DJI Assistant 2 app to retrieve your logs.
Noted - but I don't have a Mavic yet. I'd like to see some logs so I can write some s/w for it.
bbj5143
