Yes this could help. Also posting your configuration including firmware version, Control app and SD card brand/size may be of use.Thanks for coming back to post in your thread. This is the only way we have a chance to find out what's causing it, everyone posting situations in which it had or hadn't occurred. I was flying in heavy winds today also, so that's not it.
I will also discount the sunlight theory as none of my occurrences have been in this situation.I'm not sure if it was discussed before, but another theory I have is that potentially it could be direct sunlight with the drone staying in one place for longer. It's something that was typical for the two flights during which this happened.
Exactly. There were a few reports of gimbal resets back in December, probably on 0100 and they have started to come back in vogue on 0600 and 0700.Another thing to consider is: I haven't had any gimbal resets for months of flying it. These two threads dealing with the issue are not very old. Could it be a firmware issue? A memory leak or something similar - in which case ANYTHING could be causing it, and it wouldn't really matter anyway because then it's just the issue with the code in the firmware.
One thing I have noticed is the visible gimbal bumps are not always at the very start of the cache video of the occurrence. Sometimes a couple of seconds in. So the event & therefore one would assume the cause, is actually in process a few seconds before this, at very least when the cache video restarts.
Was looking at DAT of a reset I had a couple of days ago and the bump was coincident with the aircraft itself pitching down then up and not just the gimbal. Normally the gimbal hides the aircraft movements. But during a reset there is a period when it cannot do this as it has not regained alignment and it seemingly moves with the aircraft. During the yaw left you can see the camera filming the gimbal itself as it had yet to align itself and regain its travel limits. This one also self dictated the recording length being similar at 23 seconds.
BTW I use Samsung 64GB Pro+ class 3 SD card.
