Hi,
I am having an issue where the compass on my Mavic cannot calibrate anywhere I've tried. I've been out in a back yard, an open soccer field, etc. The thing just refuses to calibrate. Yes, I have read the compass calibration guide.
I've attached a few photos showing what I'm seeing. The first one is this little message that pops up on the side that says "Compass Redundancy Switch". This happens whenever Compass2 goes from green bar to just completely disappearing and saying "IMU error. It cannot be..." (something something, it's cut off in the app). So when it's on the ground, it'll fluctuate between that IMU error message and green values, but as soon as I hold it up a few inches Compass2 will all of a sudden consistently display green values all the time.
Things I've tried so far include: Refreshing the firmware (on latest one), calibrating the IMU, calibrating the gimbal, using a different battery, having a 2nd person hold the controller far far away. I've tried many things by now...
When I perform the calibration, I'm positive I am wearing nothing metallic. I can do the horizontal rotation, which I do holding above my head. As soon as I do the vertical rotation with the camera pointing downwards, it goes into the fast red blinking sequence and the app shows the error popup that there's too much magnetic interference.
Unless I have to strip naked in 32F weather and do the dance, is there anything else I can do besides submitting an RMA. I was weary of not calibrating the compass before the Mavic's first flight, but it seems to fly fine without it given both compass values are green. However, my concern is when I travel somewhere far away. And the more research I do on this, the more I suspect it's some kind of hardware or software issue. Any thoughts?
