Controller Connection Cables
MattG
Does anyone know what type of cable plugs into the Mavic controller (and then into your phone)? Is that DJI proprietary or something I can buy elsewhere? Thanks!
There is a micro USB port on the left side and a USB port on the bottom. The small cables that come with the Mavic plug into the micro USB port on the side.
Reactions: 41south
If you have a slightly thicker phone, you'll likely have a problem getting the connector into the phone socket. It becomes a worry that the phone socket will be damaged.
Just use the tiniest smear of Vaseline on a cotton bud and rub over the slider grooves and inner edges of the connector's black 'push-in' button. You'll find it a lot easier and less stressful!
testtest
