- Joined
- Dec 22, 2016
- Messages
- 1
- Reactions
- 0
- Age
- 62
On the screen of the controller I just see "CONNECTING" and it sits like that ad infinitum. Any clues on how to fix this as it has connected perfectly for months.
Hello Kym. Did you fix the problem?On the screen of the controller I just see "CONNECTING" and it sits like that ad infinitum. Any clues on how to fix this as it has connected perfectly for months.
That wont have worked because it was incorrect. You missed the Shutter button...
I tried the "rc linking" option as well as the C1+C2+Record, but no responds at all!
In fact I tried c1 & c2 buttons combinations with both the record / shutter button. Thank you for your reply anyway.[emoji8]That wont have worked because it was incorrect. You missed the Shutter button.
Correct procedure is hold down C1+C2+Record then press Shutter. (Like you were taking a photo).
I know you are all fixed now but in case anyone else is looking for the RC only Binding process.
By coincidence, this exact thing happened to me this afternoon. The controller would not connect, period. Had to take the Mavic inside and go over everything with a fine toothed comb. I must have bumped the switch when messing with the SD card. I may tape the switch over so it won't move again.Check the aircraft isn't in wifi mode, worth checking.
Thanks for this. I just had problems connecting. Got Gimbal error in Go4. Had a similar problem with my i2, so thought it was related. Saw your post and realised I had used the mavic with the Katana last week. Doh! Wifi to RC. Now all fine.Check the aircraft isn't in wifi mode, worth checking.
