Could I be having the same problem with the new RMA??
Dronebow
Got the new MP in from RMA and took it outside for a quick distance test. Same issue. Lose controller signal within 2000'. Also may have noticed some horizon tilt and while flying straight it felt like it was flying skewed. I'll figure those last 2 out but my main question is, could there be enough interference that distance is that drastically impacted??
Bugger! I guess it must be some sort of interference then but it really does surprise me!
I think I remember the previous thread or at least a similar discussion so not sure what you tried. Changing channels/frequency? If you are not in the US I believe you can change your location to be US in the actual app settings (not the Mavic settings) and then you should be able to switch to 5Ghz, this is from memory though so I may be wrong.
testtest
