Does anyone know if it is possible to create a flight record that would be compatible with HealthDrones from the DAT files stored on the aircraft? (Not from Apps on a mobile device)
When I fly certain Litchi mission that lose RC signal, the app will beeline the route between signal loss recovery points as it does not know where the aircraft went. It will always be the case on these routes due the geography & I would like to log the actual flight. Worse still, the Android Litchi app is still prone to crashing mid flight, losing the flight record in its entirety.
Of course the aircraft retains a very detailed flight log of its actual flight even when disconnected. So all the info I want is in there.
Question is - can it be pushed through DatCon or similar to create a log file that HealthyDrones can ingest?
