Dd card
microSDTM. Max capacity: 64GB Class 10 or UHS-1 rating required.
'Supports up to 64 GB' is what I found when I searched it sometime ago. I use 64 but have not tried 128.
I've read of people using 128GB cards, just not being able to format them from the DJI Go app..
Sent from my SM-G935F using MavicPilots mobile app
I am using this 128GB Lexar card, and yes, I can format from the DJI Go 4 app
You format by Mavic all new cards? Which settings you have for Video?
Just I got my Mavic and test some settings and take the card out in my iPad2 and also in my Mac mini and can't open the taken test video?
Hi, Merry Christmas.....No I don't format the new micro SD, I am used to shoot video at 4K 30fps, D-Cinelike -2/0/0 and jpeg+RAW for stills. Some post-production with Adobe Premiere for video and Adobe Lightroom for stills. My workstation is a recent IMac 27" 5K retina. Never had problems in reviewing video either with the IMac or Ipad, when shooting in NTSC and .Mov format.
Hi Merry x-mas too, thanks for your answer. All works with my Mac mini but with my iPAD 2 works only Full HD settings
I bought 2 class10 32gb ultra micro sd card yesterday for my mpro at a local cam store. And noticed from your post that your ultra card says XC whereas mine HC. Have not test the card yet and Oh boy did i bought a wrong card??
You'll be fine with those sd cards as well......just for your reference take a look here: Back to Basics: The Difference Between SD SDHC & SDXC, and Which is Best for You
I'm not so sure tbh! There is another thread on here I about the Ultra;
SD Card Error
The ULTRA cards are not certified for 4k video and even though the Mavic does not have the highest bitrate you still may receive SD Card errors. :(
Same goes for the 200GB card, not 4k certified and as I mentioned in the other thread, whilst on paper it should be fine, the real world is a little different. Hopefully you will be ok but if you can see if you can exchange them for ones that are 4k certified. :)
kmikebennett
