I received my Movario's today. I do wear glasses, and can use my prescription computer glasses with the Movario's. Even then they had some blurry edges/corners, so I used the ADB trick described in this post:
EPSON Moverio BT-300 Review Post#335 I went with 1160x720 and it worked well for me.
No flights yet, but so far I'm impressed.
Good deal. I'm not quite ready to compromise on the resolution yet. I've got an appointment with an eye doctor tomorrow and I'm going to see if getting the inserts from Rochester Optical does the trick for me. It's an expensive test but heck - I'm already in deep with my new hobby so what's another $200 right? LOL!!
So - I just did my first test flight and these are definitely going to be a keeper for me. Even with the slightly blurry edges (which I'm sure I'll solve with the inserts or the ADB resolution trick) it's far superior to using an iPad mini and it's much more convenient than the massive
DJI Goggles. The only benefits that the
goggles have over the Moverios to me is that the immersion is better and it's wireless. But the massive size and "look at me" factor offset the wireless feature for me personally.
I think the
Moverio interface with the GUI is better than the
goggles. I like having full access to everything in the Go4 app which you do not have with the
goggles.
It's overcast here this evening but I went ahead and used the darkest shades that were provided. I liked this a lot. Super clear and crisp picture no matter where I looked (even into the bright white clouds). The lighter shades are kinda pointless. Tried them and they didn't improve the video projection versus using no shades so... a waste for me. Being able to see the drone THROUGH the picture isn't that important to me. And if you're using the darkest shades with the brightness turned all the way up then you're not going to be able to see the drone through the video projection. Or at least you're not going to see it well enough to matter. These glasses are small enough that I can VERY easily look over or under the glasses without doing anything other than shifting my eyes. For instance (and I should've taken a video) I took off from my deck which is relatively tight because I have only about a 4 foot radius of clearing between the deck, the railing, the house, and a tree overhanging the deck in which to take off from. So I like to keep an eye on the drone while doing this. I could easily do this with the glasses on while also glancing back and forth from the screen to the "outside world." I also dropped down into my yard and put it in tripod mode to test out the immersion to see how comfortable I was at flying in a relatively tight spot (lots of overhanging tree branches). The immersion of the
goggles allows me to do this more confidently but the Moverios are still more immersive than an iPad mini so I still felt comfortable doing this. And if I get nervous I could easily glance at my drone (over/under the glasses or through the glasses if it was outside of the video projection).
I'm going to continue testing them. Hopefully I'll get some bright sunlight soon to really test them out. But so far these will be my go-to option. I'm debating whether or not to keep the
goggles at this point. I really DO like the
goggles so I'm hesitant to get rid of them but I'm not sure how often I'll actually use them either.
I did have a few odd things happen however.
First - the video stream was extremely pixelated at first (before taking off). I shutdown the app and started over and this mostly solved it but the stream was still slightly pixelated all the way through takeoff and until I got about 15 feet away and then it cleared up. I have not seen this on my Android phone or my iPad mini.
Second - The icon for my controller (on the screen - at the top) blinked most of the way through my flight. I've never seen this. Then it stopped blinking but the HD signal started blinking. I had full bars on both during the blinking so it was perplexing. Nothing seemed to be acting up in any way but the blinking is a bit unsettling as it indicates to me that something is wrong.
My overall thoughts - I'm super impressed. It's not perfect. But it's close enough for me to use it extensively.
