DJI Go 4 released for iOS
Still 3.1 in app store
I'm confused....why would they create an entirely new app rather than just update the normal DJI Go app?
And which one should we be using with the Mavic?
Reactions: Pete
Dunno on the first one.
The 4.0 lists only the Mavic, P4P and I2. My ASSUMPTION is we go with the latest at this point. I have not deleted ver 3 until I have gone and tested with ver 4. There may be some optimizations coming that will only work with the latest drones.
If you go on the P4P page of the app, you will see a lil arrow pointing down beside the Phantom 4 Pro name. Hit that and it will let you choose the Phantom 4.
SkyHigh Pyro Eye flying above
And just out of curiosity, what radar are you referring to? The Mavic is my first DJI product.
When I go into DJI Go 4 or the previous DJI Go app, they look basically the same.
When you hook up the controller with the app and hit the 'controller' icon, it gives youchoices on different tracking modes.
Perhaps this will fix the battery drain issue
And the radar was in the old app too
You're quite right, I've started using Litchi a lot (which doesn't have the radar, at least on the iPhone version). I was getting confused in my old age[emoji3]
You can copy the flight records folder over from the old app to the new app ON IOS. You have to do it in iTunes, but I just did it.. works perfectly fine and they show up on the new app no problem
Earlier posts said it wouldn't sync for some reason? I didn't try it
And i like that you can now play with (look at) te settings in the app without even havig the Mavic or powering it up.
Looks nice.
Can anyone confirm if battery serial numbers and stats are now recorded accurately and viewable in healthydrones? Pouring rain out here and no time to test.
skyscansurveys
