Don't forget to calibrate controller...or else this could happen!
Discussion in 'Mavic Pro Discussions' started by dsd317, Nov 10, 2016.
  1. dsd317
    dsd317 Well-Known Member
    Oct 14, 2016
    424
    217
    BTW...this is not me or my video: (If this has already been posted, please delete my post)
  2. kmaluo
    kmaluo Well-Known Member
    Oct 14, 2016
    423
    120
    That's a hardware or firmware issue. Hopefully fixed in the latest firmware update.
    Butterpuff 6 likes this.
  3. Guitarzan
    Guitarzan Well-Known Member
    Oct 25, 2016
    62
    12
    Rocky Mount, NC
    Yep, luck was on his side.
  4. Rick
    Rick Well-Known Member
    Oct 12, 2016
    146
    63
    Cheshire, UK
    This was pilot error for not calibrating the controller. Did you watch the video?
    Christopher G. Hughes likes this.
  5. Butterpuff 6
    Butterpuff 6 Well-Known Member
    Oct 16, 2016
    156
    91
    Charlotte, North Carolina
    The controller didn't give a "stick error" to prompt calibration, that's a Mavic error.
    Mr Spock and spikeanoid like this.
  6. Rick
    Oct 12, 2016
    146
    63
    Cheshire, UK
    The operator admitted he hadn't calibrated the controller (or read the manual, but that's not the point!). Are you saying that the drone should have realised that controller calibration was the problem and should have issued a self diagnostic warning message? Would that also be the same for any of the incorrect calibration issues that might occur if he hadn't done a successful IMU calibration? I'm a complete novice and just want to learn more, over and above reading the manual and watching trusted tutorials.
  7. BD0G
    BD0G Well-Known Member
    Oct 13, 2016
    880
    396
    San Jose, Ca / Lake Tahoe NV
  8. thetjshow
    thetjshow Active Member
    Nov 9, 2016
    43
    21
    shucks i didnt know about this either ... so scary
  9. Butterpuff 6
    Oct 16, 2016
    156
    91
    The only mention of doing a stick calibration in the manual is when you get a stick error. The manual says to do a compass calibration only when prompted by the app or when you get a warning from status indicator lights. The manual doesn't mention performing an IMU calibration but they did release a tutorial on how to do it. The video doesn't say when you should do this calibration though. DJI should make it very clear which calibrations should be performed prior to your first flight and when calibrations should be performed after that. Regardless of that, the expectation for DJI should be that a bad calibration will result in a warning before flight rather than a loss of control and/or erratic flight after the drone is in the air.
  10. spikeanoid
    spikeanoid Active Member
    Oct 17, 2016
    39
    12
    Good grief, how long is the list of things we need to calibrate now? I don't even have to do this for my finicky RC helis. This myth of "calibrate everything and sacrifice your first born while doing 6 jumping jacks" needs to die. If DJI expects us to do an RC calibration, they need to clearly state it, not blame it on user error.
    For the record, my mavic works fine and I haven't calibrated anything other than the compass once.
    #10 spikeanoid, Nov 11, 2016
    CAPTAINDRONE and scooot like this.
  11. The Editor
    The Editor Well-Known Member
    Oct 12, 2016
    398
    223
    Not flown anything R/C before have you? (Rhetorical)
    You cannot expect these complex multirotors to wipe your backside for you - there is only so much idiot gene filtering a manufacturer can do.
    People need to take some responsibility and take time to understand what they are using rather than whine "Oh it should have told me I'd run out of toilet paper"
  12. Butterpuff 6
    Oct 16, 2016
    156
    91
    I don't think DJI expects you to have to calibrate all of the time and your experience with the Mavic is evidence of that. I'm sure that any current glitches, will be cleared up by DJI, if they already haven't been. I expect that most everyone's Mavic will be as trouble free as the Phantom 4 was after a couple of months on the market. If people like "The Editor" get some kind of thrill out of constantly calibrating and trouble-shooting their drones, they probably shouldn't be buying a DJI product. They'll be a lot more entertained by some cheap drone with shoddy engineering and construction and half-baked software.
  13. Rick
    Oct 12, 2016
    146
    63
    Cheshire, UK
    Ok, as I already stated I'm new to the drone world, but have flown r/c helicopters in the past.
    I cannot believe that having spent a great deal of money, why wouldn't you want to calibrate everything? It makes no sense to me that anyone wouldn't want to do everything they could to protect the new asset they've invested in, not to mention issues of personal safety. if the Mavic has the ability to self diagnose calibration issues, it must have a benchmark to make such judgements. I imagine the algorithm logic within the drone must work on past calibration data. The IMU has to be calibrated for the area you live in, at least taking into account northern and southern hemispheres let alone separate continents and countries. That and any outside interference that might have occurred during transportation. Taking the time to calibrate everything before your first flight is exactly what I intend to do, especially after all the reported crashes.
  14. Butterpuff 6
    Oct 16, 2016
    156
    91
    Yes, I'll definitely calibrate everything before my first flight too. I think once you know you have good calibrations you shouldn't be calibrating every time you fly or you risk messing up a previously good calibration. The exception to this seems to be the optical sensors where DJI's manual says they require occasional calibration. I'll probably do that every two or three flights
    Rick likes this.
  15. Brice LeCarre
    Brice LeCarre Well-Known Member
    Nov 2, 2016
    115
    37
    Phoenix Arizona
    The Pilot In Command is responsible, always! No one will sue the Mavic
    The Editor likes this.
  16. spikeanoid
    Oct 17, 2016
    39
    12
    As far as I've read, these issues haven't even been confirmed to have been caused by a lack of calibrating the controller. Someone correct me if I'm wrong, but these seem more an issue of the hall sensors not correctly refreshing stick position.
    kmaluo likes this.
  17. Butterpuff 6
    Oct 16, 2016
    156
    91
    I'm suing my Mavic when it arrives. I will sue for the emotional distress it caused by making me wait so long for it.
    Brice LeCarre and mikeroycollins like this.
  18. kmaluo
    Oct 14, 2016
    423
    120
    Yes, but Mavic failures out of the PICs control, or issues that arise from what was not stated in the manual could make DJI liable.
  19. Brice LeCarre
    Nov 2, 2016
    115
    37
    Phoenix Arizona
    That maybe true, but every time you go fly, you most always bear the responsibility for damages.
  20. Butterpuff 6
    Oct 16, 2016
    156
    91
    That's why you make sure you have liability insurance.
    mikeroycollins and kmaluo like this.
Loading...
Similar Threads - Don't forget calibrate Forum Date
don't forget IMU calibration... Mavic Pro Discussions Mar 3, 2017
Don't Be This Guy sUAV Rules & Regulations Yesterday at 11:05 PM
Don't buy Mavic from B&H Photo Mavic Pro Help Yesterday at 3:01 AM
What if Airport Operator and ATC don't Answer? sUAV Rules & Regulations Thursday at 2:48 AM
DJI fighting to make it so you don't have to register your Mavic sUAV Rules & Regulations Mar 13, 2017
Share This Page
