FCC vs CE range.
Discussion in 'General Discussions' started by MavicKhan, Oct 22, 2016.
  1. MavicKhan
    MavicKhan Well-Known Member
    Oct 15, 2016
    236
    104
    Cascais, Portugal
    The US FCC compliant range for the Mavis is 4.3 miles.
    The EC one is 2.5 miles.
    A while ago, when I was considering buying a Phantom, I remember there was a simple way to revert a unit bought in the EC back to the FCC range (a recessed button in the controller?).
    Do any of you happen to know if this will still be possible in a Mavic sourced from a EC country?
    Thanks
  2. Mad_Angler1
    Mad_Angler1 Well-Known Member
    Oct 16, 2016
    116
    48
    Wales UK
    No it's set via GPS location, there is only one version of the craft, the output can not be changed, depending on where the craft is it sets the output based on that
    So bring your craft to US and it's in FCC, take that same craft to U.K. and it will set its self to CE.
    This is not changeable.
  3. MavicKhan
    Oct 15, 2016
    236
    104
    Cascais, Portugal
    Thanks.
    Major, major bummer....:(
    MK
  4. nocaps
    nocaps Well-Known Member
    Oct 12, 2016
    185
    76
    Another way of looking at it is that the change is easy, all it takes is a plane ticket.
  5. stealle
    stealle Well-Known Member
    Oct 12, 2016
    290
    155
    How does this translate in real world performance? Is the range limited by actual distance between the controller and the drone? Or, does the controller have reduced output in CE mode?
    Or to put it another way... let's say in FCC mode you can only get a range of 2 miles because of the conditions are not ideal. Will you still get 2 miles in CE mode under the same conditions or will the controller have reduced performance in CE mode causing maybe a 1 mile range?
  6. Bernard
    Bernard Active Member
    Oct 12, 2016
    32
    6
    Will be changed with the Brexit negociation ! :)
    botasky likes this.
  7. Mad_Angler1
    Oct 16, 2016
    116
    48
    Wales UK
    Reduced output.
    The Mavic has more power output than the P4 in CE and I have had that over 4 miles in the correct contusions so it not an issue.
    It's all about the environment not the output.
  8. Guest
    Guest Guest
    Basically it will adjust transmitter power output from both the remote controller and Mavic itself.
    When in FCC mode (based on GPS location) the remote controller will output ≤26 dBm (that's just under 400 mW)
    When in CE mode (again based on GPS location) the remote controller will output ≤20 dBm (that's 100 mW)
    I do not know the downlink power output (video stream / telemetry) from the Mavic itself is, but this will be controlled the same way.
    (edit): "Better" antenna's (more dB) / and position are a key factor most of the times for a better range
    #8 Guest, Oct 23, 2016
  9. 4wd
    4wd Well-Known Member
    Oct 12, 2016
    600
    203
    North York Moors
    Since about 2 miles is easily possible with P3A/P on CEE - with good line of sight conditions - I suspect DJI's Mavic range estimate is conservative.
    Transmitter power does not produce a linear response in your ultimate range.
    More is generally better of course...
  10. RallySoob
    RallySoob Well-Known Member
    Jan 6, 2017
    344
    132
    This is very interesting.. how can we confirm that our US mavic's are running in FCC mode?
    So are they advertising a 4.3mile range in countries that can only get the CE 2mile version? Just curious..
    Im sure it can be hacked if u do want to change it. Ive seen a hack for the p3p but not sure how all that works myself
    insainflow likes this.
  11. msinger
    msinger Well-Known Member
    Approved Vendor
    Oct 12, 2016
    4,263
    1,753
    Harrisburg, PA
    There is no way to visually check. This setting is set based on your Mavic's current GPS location.
  12. Jordan
    Jordan Well-Known Member
    Jan 5, 2017
    119
    71
    London
    Does anyone know/heard about MagicPower 5 for the Phantom 3/4K that can change the DBI of the remote from 17 to 27dbi? I used this on my Phantom 3 standard to improve its performance but dont know if its possible to trick the Mavic.
  13. Neil
    Neil Active Member
    Dec 15, 2016
    25
    14
    God's Own County. (Yorkshire)
    Yeah I used that on my P3S. I guess it's just a matter of time until someone comes up with the same thing for the Mavic.
  14. Jordan
    Jan 5, 2017
    119
    71
    London
    I just got a 6km run on mine in the UK, good location maybe in more urban environments the extra dbi provided a stronger signal but in clear locations it's getting well over the stated CE figures.
Loading...
Similar Threads - FCC range Forum Date
Range limitations CE and FCC... going over? Mavic Pro Discussions Nov 1, 2016
FCC & CE versions same device or are there to of them? Mavic Pro Discussions Mar 4, 2017
DJI FPV Goggles FCC compliant? Mavic Pro Discussions Feb 26, 2017
FCC approves DJI googles Mavic Pro Discussions Feb 23, 2017
Different versions of Mavic pro? CE & FCC General Discussions Feb 20, 2017
Share This Page
