could be better. Need to figure out what I need to do to make it better.
Are you fishing for suggestions? If not, stop reading at the upcoming period.
If you are, keep in mind I'm no Martin Scorsese, but here's my unwashed opinion to be taken for what it's worth: The ramblings of some random guy on the internet.
1 Gotta get closer. The extreme altitude made the subjects like ants. I couldn't see if the skier was waving at the camera, had fell off, or was a poodle in a poodle skirt. 40-50 ft instead of 100+ would make a huge difference. Given the title was along the lines of Mavic Goes Waterskiing, I saw more beautiful backdrop than I did skiing.
2 Frame your shot and follow through. Several times the boat was well on its way out of frame before you moved to keep up. Being the subject was a boat, it would work well to keep it in the center third, or let it lead you. You'd never want to stop moving and let your subject exit from view, unless you're transitioning to another subject in frame.
3 Dump the music. The track selected really doesn't belong with the subject matter...unless you're in the face of the action. Minutes of silence or a light classical track would've been more appealing given the overall "slowness" of the video.
4 Slide out slide in transition effects are better used to join clips of differing look, whereas a simple fade or dissolve would be more attractive in this scenario. Seeing the water slide out and back in again painfully triggered my ADD wondering what the heck just happened.
Of course, "better" is highly subjective, and I won't go comparing against others. What matters is if you're proud of your work. Are you?
By your own words, you're still pretty green at the whole thing, and that's perfectly okay. All of us started somewhere. Be proud you tackled the challenge and came out of it with usable video and without crashing. Going by all the crash threads, a lot of people have problems successfully flying over land, which you're already a step up.
Keep flying, keep editing, and things will naturally fall into place. [emoji106]
