Yes.Does it also show YOUR location as you search
It seems that the two apps do not share flight logs - or at least my Litchi missions don't show in DJI Go.
Curious as they share the same SDK. Usually a log is an SDK function. I need to download it and see...
So if you lose your aircraft while using iOS Litchi you're SOL since you can't fire up DJI Go to resume where Litchi falls down.
Thanks!!! Good to know. Seems mine had issues switching once but the details are fuzzy.Actually, you can. If I remember correctly, I switched right away to DJI Go, which was able to communicate with the drone and note it's location. Then, it was just a matter of battling my way through the brush and tall grass, with DJI Go updating my position as I moved closer and closer.
