Hey guys, I found a pretty good orientation I think works pretty well if you want to try it with an iM2200 of your own - hope this helps!
Outside of the Pelican Storm iM2200. I've attached the Pelican shoulder strap to the case to make it a bit more convenient to carry long distances.
Top layer - everything I need for a quick flight; I can grab the Mavic, battery, controller, mount and props and just go.
To store my tablet I use with the MavMount - the NVIDIA Shield K1 - I cut a slit in the middle of the top foam so I can slide it down inside. This solution actually works really well and keeps the tablet safe. I attached some velcro to the top inside of the case and the top of the foam to keep it from simply falling down from the additional weight.
With the Mavic removed, you can see I carved out additional space under the drone for additional "quick access" storage. This is where I throw connector cables and additional props should they be needed.
If I need other parts of the "Fly More" kit - like the battery hub or charger, I simply remove the top foam layer and have full access to these items as well.
Hope this inspires your own creations!
