Flight Photos and Videos with dji Googles
Xblog
Hi,
is it possible to view videos flights made without googles ? i insert SD card on Googles but none... :/
have you tested this ?
Thanks !
Hi,
Thanks !
It'll only play up to 1080p video recorded from the aircraft via the SD card slot. You'll have to use the HDMI in for all other video.
if i use the sd card on Mavic to googles, googles dont find video, is it normal ?
Xblog, I had the same problem. DJI has. Determined that the goggles are defective and are being returned for repair.
in fact, Google just read 1080P videos ... "t'll only play up to 1080p video recorded from the aircraft via the SD card slot. You'll have to use the HDMI in for all other video." > Correct
i test it and it works.
i hope dji upgrade this with firmware release
kclarke2929
