My 7 plus doesn't work-- completely!!!
WEAK GPS error when trying to use follow me or changing home point!!!!
Will not work!!!!!
Tried changing cables- remove- reinstall app-
Even went to Apple Store and exchanged for BRAND NEW 7 Plus--
It didn't work either - doesn't work--
All other functions and modes work perfectly.
Fits in controller wonderful even with Case still on the phone.
But I bought the drone specifically for the follow me mode and it's unusable with my fancy expensive 7+ iPhone.
Very frustrating
Follow me does work well with all 6S plus and also I pad mini that I tried.
Bought a cheap refurbished acer 7 inch tablet for 63 bucks and GPS works perfect on it but it is android and android is not as smooth as iOS and the maps suck.
No
That is not the proper way to use follow me.
That if you could change the home point.
That does work on my old 6S plus as well as an old iPad mini and a $60 acer 7" tablet---but will not work on my fancy brand-new expensive iPhone 7+!!!!
Are you on AT&T by chance? There are a few users having trouble with follow me and setting the home point to the controller using 6, 6s & 7 iPhones. The ones I know about that are having trouble, including myself, are all on AT&T. May be too early to tell but that may be the common denominator.Has anyone figured this issue out? I am using an iPhone 6s and no matter where I go, follow me mode just simply won't work. It says I have a weak GPS signal and that's all i can get.
Yes I am, that is an interesting theory, it seems like it is the only expiration though. Thanks for sharing this.Are you on AT&T by chance? There are a few users having trouble with follow me and setting the home point to the controller using 6, 6s & 7 iPhones. The ones I know about that are having trouble, including myself, are all on AT&T. May be too early to tell but that may be the common denominator.
Theory is that iPhone 7 uses an Intel modem that is inferior to the Qualcomm modem. This causes, at times, inferior reception and apparently affecting GPS performance. I am no expert but I would like to gather more responses from MP owners and see for sure if this error is only happening to AT&T iPhones.Yes I am, that is an interesting theory, it seems like it is the only expiration though. Thanks for sharing this.
This is intriguing, I hope to hear some more responses about this. A good test might be to take a phone that's on at&t and a phone that's on a different network and fly in the same area with the same drone where the at&t phone won't work on follow me. If I get the chance I will for sure try this out.Theory is that iPhone 7 uses an Intel modem that is inferior to the Qualcomm modem. This causes, at times, inferior reception and apparently affecting GPS performance. I am no expert but I would like to gather more responses from MP owners and see for sure if this error is only happening to AT&T iPhones.
Thanks for your input. I thought the intel modem was new with the iPhone 7, but was not sure.Did that test with all on AT&T--
7 plus weak signal- never able to connect
6 s plus good signal- worked well
IPad mini good signal- worked well
Just FYI- only 7 plus had intel modem
This works for US iPhones, curious what European iPhone 7s show.....No, I don't. But if the Swedish ones are Intel, ours would probably be too.
