Mavic_Man504
- Joined
- Oct 18, 2016
- Messages
- 84
- Reactions
- 3
- Age
- 52
from what was mentioned earlier that's not the case
Sent from my SM-G935V using MavicPilots mobile app
That would require opening the battery to isolate individual cells. Not ready to do that with a brand new battery. I wasn't looking closely at voltages in DJI Go while I was flying since I was staying close by and relatively close to the home point.couldn't you use a battery/cell tester to see what percentages you're getting per cell?
DJI Go does display the voltages.So where you set up the low battery warning levels it doesn't show an overview of the cells in the app?
Oh okay lol, I was confused I'm sorry.. I was hoping that it does still pull data from the individual cells.. Kinda had me worried..Steve, I was only referring to the TXT flight log. DJI GO is not storing the battery data in the log for some reason.
Without the battery data I couldn't determine the cause. But, maybe what I did find will help someone else determine the cause. The signal SMART_BATTERY.goHome falls to 15 at about the same time the flyCState is set to ForcedLanding.Was flying just now and as I was heading in the broad in DJI Go says "LANDING". Tapping the red X on the screen didn't abort it but I was able to override it similar to fighting autoland in the P3/P4. As soon as I let off the sticks it would go back and say LANDING. I was over water and about 200ft away. Battery was not even close to low yet. I landed shortly thereafter with 39% left.
The ForcedLanding is the teal background. It's not evident, to me at least, why the SMART_BATTERY.goHome falls to 15. It may in fact be the result of flyCState set to ForcedLanding.
It does get set to 15 on or right after every forced landing in this log. It's an interesting observation, but I'm not sure it's the cause of the forced landing.It's not evident, to me at least, why the SMART_BATTERY.goHome falls to 15. It may in fact be the result of flyCState set to ForcedLanding.
Your flight log shows they were set to 30% and 10%.I'm pretty sure they're both set to 15% in DJI Go
Oh OK I may have changed them for the Mavic to make sure I didn't get carried away. With the P3, I had them turned all the way down due to distance flights.Your flight log shows they were set to 30% and 10%.
Yeah, I have to agree it's not related to the battery. In my post I alluded to the possibility that the ForcedLanding causes the SMART_BATTERY.goHome to be lowered to 15. With the P3 if SMART_BATTERY.goHome rises above SMART_BATTERY.battery then a GoHome is triggered. Maybe here SMART_BATTERY.goHome is lowered to reduce the possibility of a GoHome whilst in the ForcedLanding state?It does get set to 15 on or right after every forced landing in this log. It's an interesting observation, but I'm not sure it's the cause of the forced landing.
When the first forced landing occurred, the battery was at 42% and the voltage was 3.69V (assuming the cells are perfectly balanced). So, it doesn't seem the issue was caused by a low battery.
Ed209 you can adjust the gimbal horizon both in flight and on the ground. Select the HD camera in the settings and select manual gimbal Adjustments just like the P3 and P4
The full stick down in combination with what seems to be a bad downward sensor reading is what seems to be the cause here. On the first two unexpected forced landings, you had the throttle in the full down position and the downward sensors were detecting that your Mavic was 0.32 feet from the ground. I'm guessing this is being caused by either a Mavic firmware glitch or your Mavic sensors might need to be recalibrated.Closer review of the flight in DJI Go showing stick inputs shows that I had 100% left stick down during the first 2 events at 11:27:17 and 11:35:09. I was descending to bring it down at that point. It's like it started the auto land nanny feature only I wasn't hovering a few feet off the ground; I was 95ft and 91ft respectively.
I'm assuming that downward sensor means OSD.sWaveHeight? And, if it's not 0 then it's a valid measurement? If so, then looking at this flight and a couple of others from my Mavic it seems like a ForcedLanding is triggered whenThe full stick down in combination with what seems to be a bad downward sensor reading is what seems to be the cause here. On the first two unexpected forced landings, you had the throttle in the full down position and the downward sensors were detecting that your Mavic was 0.32 feet from the ground. I'm guessing this is being caused by either a Mavic firmware glitch or your Mavic sensors might need to be recalibrated.
I had a Phantom crash in the water and DJI covered it under warranty by sending me a new one. They never asked for me to send back the lost unit.If the theoretical water 'landing' resulted from a defect with the mavic, then it doesn't even seem like dji care is applicable. Dji care isn't a substitute for the warranty that accompanies the mavic, but is an add-on to cover damage caused by misadventure or bad luck.
Sent from my HTC_0PJA10 using MavicPilots mobile app
