- Joined
- Jun 21, 2017
- Messages
- 24
- Reactions
- 0
- Age
- 28
Yeah, then entire gimbal/camera is quite hotAre any of the gimbal motors getting hot?
Also, just turned it on again. It does seem to be acting differently. beforehand it only ever went up and down. Now it does move to all angles it just does not respond to commands still. Also it seemed to of made a strange high pitch squeal before which it never used to make. It only happened for a second or two maxYeah, then entire gimbal/camera is quite hot
I got this video of the squealing I mentioned and the way the camera is actingAre any of the gimbal motors getting hot?
You think its something to do with the cable? Or the gimbal controller or something? Would it be best to carry on trying to fix it myself or maybe send it to a professional?Your pitch motor is not happy and is prob very hot.
Ah okay, well ive ordered a different cable off of a company with better reviews. It will be here Monday so i will try that and if it still doesn't work I will send it off. I will keep you updated palIt could be the cable, or could be the motor assembly. I just think that motor has had it.
Im getting the new cable delivered tomorrow, hopefully it fixes the issue otherwise it'll be an expensive crashI have the same issue, my drone droped from 2 meters gimbal problem.
See picsView attachment 15776View attachment 15777
I got a new one of them cables coming tomorrow. Fingers crossed this finally sorts out my baby so she can fly again!If you mean the damage to the pins, yep! Those pins on the connector will cause an error if even 1 gets bent out of shape. You can replace that ribbon cable which goes from the top of the gimbal to the board.
Sooooooooooooo this is getting a joke haha! The gimbal is fully working now after replacing the F1 cable. When all of a sudden my camera is now flickering blue lines? The camera works perfect fine just every second or so a blue line flicks across the screen?Hope it does.
Iv'e repaired the LVDS cable. The flickering seems to still be there now just the blue lines have became purple? Any idea what else could be causing the flickering video? The gimbal works perfectly now, once I sort this flickering issue it'll all be fully repairedHope it does.
