Why not just put the FAA number on the side sticker instead of a long message telling them to look under the battery?I've put the FAA number under the battery, and sticker on the side stating "FAA number under battery". We have to assume whoever finds the MP may not know to look under the battery.
The other side has my phone number and "reward if found". I've also put the FAA number on the RC (between the two antenna). This way, if approached, I can show it to them even if away from the case or the MP is in the air. To answer OP, I have not been asked about it yet.
I agree and buy into the community of good Samaritans idea. However, what's the motivation implicit in your assertion that you have to be legit because people are calling 911. Is it the idea that it's more and more likely that an officer of some sort question you about your lawful use of a drone that a civilian found concerning and that so long as you got your sticker, you'll probably be fine?I put a small sticker of the registration number on the right rear leg. You have to be legit considering how often people are dialing "911" on drone pilots.
Sent from my XT1650 using MavicPilots mobile app
