Help Flickering
Neto
I know this is probably a simple question and not related with the Mavic itself, but looking at the last two takes of this video, anyone could help me with the flickering image when panning vertically?
Thanks a lot for any input!!!
Reactions: renton82
nobody? ;)
If you can give a time on the video that would help.... it's a 5 min video, I watched 1:30 of it and gave up...
Also, did you mean flickering during the TILT of the camera? (up or down).
Thank you CactusJackSlade.
It's the two last takes of the video.
The two 90° last sequences over the beach.
The gimbal is pointed down all the time, but the image is not smooth.
From 4:40 to 4:50 and from 5:00 to 5:05.
Since english is not my native language, I'm not sure if flickering describes exactly what I mean.
I'm referring to a camera movement not smooth kind of jumping as if there was a compression problem.
But even without compression I had the same issue.
I thought I would see the same problem which I am often experiencing.
This video is recorded in rather dark environment, but this flicker often appears in sufficient light also.
So last week I have sent my mavic for an assessment and today I have received an e-mail stating that both camera and gimbal will be replaced under warranty.
Here is another video regarding this issue.
Glenn-S
