Looks like it is screwed in from the top inside of the frame. You could probably 3d print one, or bend that shape out of thin aluminum sheeting. The hardest part will probably be taking the drone apart to reach those screw.
I tried to 3d print one but it wasnt firm enough. Too small.
And to install it you do have to take off the top cover which is not too difficult if you have time and patience, and remove all the screws required from the top and bottom of the Mav. 6 screws top, 4 screws bottom.
My worry is I'll get it apart and that will be a dji installable part only . Thus voiding my refresh warranty. If it's a rivet holing it on from the top. I'm thinking using a solid piece of aluminum flat that shape. Then bending the folds into it , and away I go. Not sure if it will work or if I should attempt it .
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
