Home wifi router causing signal interruptions while flying within range of it?
xUNx DeathDrone
Does anyone know if a router inside a house that is on can cause a possible signal interference if you are within range of it?I put my phone in airplane mode when I fly, but Im curious if the actually router could be a cause of signal interference? Ive only flown once at a location other than home and I had zero signal issues.
Go to the app store / play store and look for a wifi channel analyzer - check to see what channels are causing the interference and manually set the mavic to a different channel.
interesting, didnt even know that was something i could do. How would i change the channel in the mavic?
jridout
