What kind of damage is normal?Inspect them carefully for damage prior to each flight. Change them when they are damaged.
Even small scratches from the grass?No damage is normal. Other than scuff marks from folding them, they should be as pristine as the day you unwrapped them.
I would happily use that blade.I'm very new to this. Sorry about silly question...
...I am wondering how that small cut happened. Was it the winds, or maybe it was me trying to take out the bird from its leather case it came with (combo box) .....
My guess could be hitting bugs in the air possiblyThat chipped blade was after my third flight. On that flight there were strong winds and maybe a few rain drops. There was absolutely no accidental touch of the blade to any obstacle and the landing happened to a clear terrain. I am wondering how that small cut happened. Was it the winds, or maybe it was me trying to take out the bird from its leather case it came with (combo box) .....
Not so sure you're 100% correct with that observation.Don't use that! The crack will spread under flight load and the blade may disintegrate with the imbalance. Your drone will crash if that happens!
