Robert Granata
- Joined
- Dec 25, 2016
- Messages
- 367
- Reactions
- 381
- Age
- 67
That's great. When I tried it and it didn't work, I just landed and used the app to reset the home point to the drone's position. I didn't think of turning off the props.EUREEKA! After 138 posts I can finally answer part of my original question.
The ATOP (altitude at take off point) does reset once the props stop. And no Bothans died to get us this information.
I found a park at the base of a steep mountain slope, and there was a walking path that went from that park up the side of the mountain to a height of 400+ ft above the park. I took off from the park and landed very carefully on the path, and in the instant the props stopped the altitude reset to zero. Unfortunately, a second later I got the message that the connection to the Mavic was lost. And as everyone knows, losing connection when in the air is no big deal thanks to RTH. Losing connection on the ground with the props stopped leaves you SOL. So I started running toward the path, not certain if there was some software reason why I'd been suddenly disconnected. Fortunately, I only had to run 100 ft or so before Ready To Fly came back. At that point it was easy to take off and I was able to ascend an additional 1640+ ft.
So, this opens a couple of more questions.
1) If a Mavic is above you and on the ground, is the onboard antenna always somewhat blocked by the ground?
2) Theoretically, if you were to kill the props at Max Altitude, would the altimeter reset, and could you then regain control?
I would be really interested if a flier who is spending someone else's money could test question #2. I've been pretty adventurous so far, but that is not something I'm going to test.
Many Happy Returns
1. I think you are right about the signal being blocked by the ground. Maybe find a jutting outcrop to land on?
2. Maybe we can get Casey Niestat to test this.
