How to fix firmware update fail?
wngan
I turn on my Mavic today and try to fly if. It show need to update firmware, so I update it, but keep get fail. What I can do now? Please help.
It than it look like stuck at 21% than will told me update fail
#1. You can still fly without updating your firmware while to try to figure it out.
#2. What kind of device are you using?
#3. Are you trying to update "DJI GO 4"?
hello to everyone anyone who can help to configure out this problem can help .... I have mavic air and I tried to update it's firmware but did not work... the update keeps failing for the remote and it won't fly anymore - I really need your help please
I take a shot.....Turn off your ad blocker and Anti spyware Programs Make sure you have a good conection and shut down any programs running while trying to Update your firmware
....and try another Cable ....cR
thank you so much for the help, and also I would like to know how to remove main controller data error
And you might also try to do the update "hardwired", as in using a Lan cable from pc to your modem/router.
Sometimes the signal from the Mavic ac/controller can "blow out" your wifi signal from your router.
I had the exact same issue when I open the box to register my bird, (but not/never updated anything). Once I used the Lan cable (only had to do it once), all was happy happy happy....
James Hoogenboom
