IMU & Compass Status function gone?
Ronpan99
Hi,
I haven't flown in since 6/16/17 until today, but has anyone lost the function to check the compass & IMU status from the start-up Aircraft status. They both say Normal, but I am unable to check them and look at the status numbers as before. I'm using version (v4.1.2).
Is there a way to get it back or to look at them from a different pathway?
Thanks,
Did you try going to MC Settings, Advanced Settings, Sensors state?
I didn't try that. It worked. Thanks. I'm use to checking it from the Aircraft Status screen. Hopefully they didn't take that function away or maybe they will re-instate it. Much appreciated.
You'll only be able to calibrate the compass from the Aircraft Status section when DJI GO detects a compass error and/or thinks the compass needs to be calibrated. The compass can always be calibrated from the following section of DJI GO:
Reactions: Ronpan99
maviclake
