iPad mini 4 wifi -pas besoin du modèle cell - La Solution! dossier pas à pas
debric france
Do you need to use Follow Me or reset the home point to your current location after taking off? If not, then the Wi-Fi only model will be okay to use.
Reactions: debric france
Yes, those steps will be helpful if you need to connect to the Internet. You cannot share GPS data like that though.
Msinger
Thank you
My goal was to use gps this way.
I am afraid to loose my drone that why gps is important for me.
Anyway thank you a lot for your help!
GPS on your mobile device isn't going to prevent you from losing your drone. It might be helpful if you're moving around while you're flying though (e.g. flying from a boat).
bbj5143
