Keeping the camera pointing at an object
P.19; "...The remote controller can be used to maneuver the aircraft, but yaw is disabled. Using the left stick and gimbal dial will adjust subject framing...."
How can the left stick be used if yaw is disabled?
Does it mean the stick will not turn the AC but it will frame?
elevation change only, not yaw.
-- Does it mean the stick will not turn the AC but it will frame? --
Yes, the left stick affects the left-right position of the subject in the frame, instead of directly yawing the drone.
Tenakeetwo
