Launching in grass
Discussion in 'Mavic Pro Discussions' started by Mattman, Oct 27, 2016.
  1. Mattman
    Mattman Well-Known Member
    Oct 17, 2016
    96
    27
    I find that due to the low profile of the Mavic, even launching it off grass is problematic (hits the props)...so I put a doormat under it. Obviously I don't want to have to lug that around so I'm wondering what other ideas are for launch clearance?
  2. Deckyon
    Deckyon Well-Known Member
    Oct 12, 2016
    466
    189
    There are a ton of answers already on Launching. A quick search should bring those up.
  3. Mattman
    Oct 17, 2016
    96
    27
    I'm looking for a diversity of non hand-launch solutions from people that have flown the Mavic a few times. Thanks though.
  4. DesJardins
    DesJardins Well-Known Member
    Oct 26, 2016
    66
    23
    US, Arizona
    I'm still a hoodman launch pad fan... expensive though
  5. F6Rider
    F6Rider Well-Known Member
    Oct 15, 2016
    956
    383
    Sunny California
    Hoodman?, $$$ Just a cheap rubber door mat from Walmart will work just fine, heavy enough not to blow around, black square easy for the camera to detect, can roll it up (I roll mine up and stick it in the tripod slot on my pack) easy to clean, and cheap to replace.
    Alex Baxter likes this.
  6. msinger
    msinger Well-Known Member
    Approved Vendor
    Oct 12, 2016
    4,213
    1,728
    Harrisburg, PA
    If you must launch from grass, then try tamping a small area down with your foot. That should allow the props to clear it.
  7. mtrecon
    mtrecon Member
    Oct 13, 2016
    7
    1
    Opinion on the 3' hoodman being heavy enough to use with the Mavic without staking it down. I know the diameter is fine.
  8. kmaluo
    kmaluo Well-Known Member
    Oct 14, 2016
    423
    120
    The only problem is I fear that I grass may still get into the sonic sensors. I just finished a couple flights using a 2x2 foot cardboard square and it works great for not too windy conditions. The Mavic doesn't blow it around unless you hover for several seconds at around 5 feet. Anything lower doesn't blow it when centered. Still trying to get precision landing more precise though. Lol. It's cool that you can still minor adjust the last foot of landing after confirming a landing command.
  9. GMG
    GMG Member
    Oct 21, 2016
    20
    4
    I'd ordered a bullseye spirit level and was going to put it on a cheap, IKEA-like tray and use that for my other drone which needs to be calibrated and paired on a level surface. I can simply adjust rocks under it to ensure it's level. I'm assuming the Mavic doesn't need it to be level, but thought that I'd us that for the Mavic as well, assuming that I throw it in the back of the car when I fly.
    Incidentally, I had a little Hubsan X4 that required calibration on a level surface and I used to simply put the level on the IPhone (using the inbuilt compass app), level it out and then put the Hubsan on that to fly it of that. Clearly not a solution for the Mavic :)
  10. DesJardins
    Oct 26, 2016
    66
    23
    US, Arizona
    Just an option for the OP if they want to be fancy... I like being fancy ;0)
  11. stealle
    stealle Well-Known Member
    Oct 12, 2016
    290
    155
    rear floor mat from your car
    F6Rider likes this.
  12. dsd317
    dsd317 Well-Known Member
    Oct 14, 2016
    423
    217
    Here ya go:
    Structural integrity while landing
  13. dsd317
    Oct 14, 2016
    423
    217
  14. Mako79
    Mako79 Well-Known Member
    Oct 13, 2016
    354
    156
    I will be doing belly-take-offs.
    Check for snakes and drop bears first.
    Lay down on your back in starfish position.
    Place Mavic on belly with camera looking at crotch (you can see the status lights and helps with orientation after take off).
    Make sure you have sunnies to minimise glare and dirt from the prop wash.
    Keep still after take off so the Mavic's belly camera can take pic for accurate RTH.
    Make sure you remain in the same position for the entire flight. This will help the RTH belly-landing.
Loading...
Similar Threads - Launching grass Forum Date
Launching on a boat Mavic Pro Help Feb 27, 2017
Hand launching and small props? Mavic Pro Discussions Feb 20, 2017
Launching from Tripod mount General Discussions Feb 17, 2017
Hand Launching Mavic Mavic Pro Discussions Jan 1, 2017
Hand Launching and Catching with protection Mavic Pro Discussions Dec 7, 2016
Share This Page
