Litchi waypoint settings question
tmw2023
When you edit the speed is that the speed the drone travels to the way point at?
Yes.
You can use the same speed for each way points. Or change every single one.
You can also use the throttle during the mission to go faster between way points if you want or need it.
carlos22
