Low flight
leesmavic
Can this bird fly low like 10 cm above ground? It doesn't go lower than the height at witch it initiates landing. At least I can't make it do so.Can you fly through a tight space like a small window when there is not much space below it? There is a stunt track for 'dumber' drones here where people practice unaided piloting. It includes loops to fly through, large tubes, windows etc. I wonder if I will be able to fly with a Mavic there.
You can fly low to the ground if you turn off the downward sensors in DJI GO.
Or you can put it in sport mode and turn off all sensors.
Im not sure flying in sports mode that close to the ground is a good idead :) .... well not for me anyway :)
Reactions: F6Rider
You could leave on the vision positioning, fly at that minimum height allowed by the vision system and use the 2x digital zoom to appear nearer to objects while having an even greater safety margin from potential impacts.
Albrecht0803
