Map not following Aircraft in DJI Go app
Discussion in 'Mavic Pro Discussions' started by gregw, Nov 25, 2016.
  1. gregw
    gregw Well-Known Member
    Oct 16, 2016
    108
    50
    I remember in the older version of the DJI Go app, the map always defaults to following the aircraft, and shows the line pointing towards "Home". In my flight today, there was no way for me to get the map to follow the aircraft. It seemed stuck at "Home". If I tap on the small map so it expands, there was a symbol I could tap which opened up either "Home" or "Aircraft" symbol. If I tap on the "Aircraft" symbol, the map will shift around and center itself on the aircraft. However, it still does NOT follow the aircraft and simply just stays at that point, so when you fly away from that location, the map is just showing the track of where your aircraft has been.
    How do I get the map to follow the aircraft like it used to do?
  2. rockydog
    rockydog Well-Known Member
    Oct 18, 2016
    139
    41
    London UK
    Be careful what you're tapping on! When you tap on the Home or Aircraft symbols, you are re-setting the Home Point to either where your controller is, or to where the aircraft is at that moment.
  3. gregw
    Oct 16, 2016
    108
    50
    Is that what's really happening? Hmmm.... Are you sure this is to set the home point? I did a screen capture of the screen on my phone without connecting up the Mavic.
    After clicking on the Aircraft symbol, the map simply shifts to the aircraft. There is no pop up or voice saying that the home point has been updated...
  4. Crashburn
    Crashburn Well-Known Member
    Oct 12, 2016
    51
    32
    Agree, the new "Here" map does not scroll and is a pain to switch to full map to see where you are, hope a fix is coming
  5. rockydog
    Oct 18, 2016
    139
    41
    London UK
    I think I have given you bad information regarding the symbols on the map. I think, as you have discovered, that they just centre the map on either RC or Aircraft.
    The re-setting of the HP I described is done In the MC settings page in the app. Apologies for the bad info.
    superdave5050 likes this.
  6. Fat Bastard
    Fat Bastard Active Member
    Oct 26, 2016
    36
    12
    U.S. Southwest
    Any resolution to this? I have the same issue... Or do we have to wait for a firmware update?
  7. mike venziano
    mike venziano Active Member
    Nov 4, 2016
    44
    11
    mine is broke also broke
  8. kodiak1120
    kodiak1120 Well-Known Member
    Oct 17, 2016
    132
    63
    I updated the firmware today and I'm running the most current version of DJI Go 4... Map is following again.
    SeaFox and Fat Bastard like this.
  9. F6Rider
    F6Rider Well-Known Member
    Oct 15, 2016
    937
    357
    Sunny California
    I flew 4 flights today on the new F/W and yes the map is now following again, thank goodness, it was a PIA before.
    #9 F6Rider, Dec 26, 2016
    boxsterfahrer likes this.
  10. Fat Bastard
    Oct 26, 2016
    36
    12
    U.S. Southwest
    Cool! I just did the update and will see how it goes tomorrow. Sounds encouraging.
  11. F6Rider
    Oct 15, 2016
    937
    357
    Sunny California
    Love your Avatar by the way, great movie!
    Fat Bastard likes this.
  12. kodiak1120
    Oct 17, 2016
    132
    63
    True that!
Loading...
Similar Threads - Map following Aircraft Forum Date
Map Auto Rotate on DJI Go AND Litchi is now gone. Mavic Pro Discussions Sunday at 8:27 AM
Maps made easy General Discussions Saturday at 4:43 PM
Maplin have stock (UK) Mavic Pro Discussions Friday at 2:55 AM
Alternative Maps Mavic Pro Discussions Thursday at 11:30 PM
3D Mapping Software recommendations Mavic Pro Discussions Thursday at 11:25 PM
Share This Page
