Mavic 1080P 60fps
waxings
What movie resolution are most of you all filming in? I have not had a chance to get in many flights but when I looked at the few shots I did get the don't look that good. I know the first questions will be did I tap to focus. Yes I did and they still look off. I typically get up around 25' and focus on a object 75-100' away. I will try and post some samples later today.
Do any of you have any sample video shot at 1080p 60fps from your Mavic?
You can use it but it is riddled with moire. I would stick to 2.7 or 4k then up it to 60fps in post if you have to :)
That is exactly what it is going on. Thanks guys for the help! I will change to 2.7K.
Just to add it is a hardware limitation however they my be able to tweak it down a little with f/w updates but it will still always be there imho.
skyscansurveys
