mikesher
On the overview page, it showed the max temp was 32 degrees, but if you click on that number the detail it shows 89 degrees. (I just had to double check)
Click on the number (32 degrees), the detail shows something different. A bug for healthy drones perhaps?Went back to the Healthy Drones report and sure enough it does list the Max Battery Temp as 32 degrees Fahrenheit. Thats the MAX battery temp not the minimum meaning that battery temp could have been less at the beginning of the flight.
you too...i said IS IT ESSENTIAL not IT IS ESSENTIAL...therefore i was asking a question not telling people to do it...read carefully
could be a bug...lolClick on the number (32 degrees), the detail shows something different. A bug for healthy drones perhaps?
no, scroll up to post 102, its circled in red, 32 fIs it possible you guys are talking about different units? 32C = 89.6F.
Watching the video it clearly looks like it is much warmer than freezing.
Edit: you guys are fast!
I've never seen DJI mention that topic. If it was a problem, we'd routinely see hundreds of DJI aircraft dropping out of the sky on the same day each time the K-index was high.
This will be a non-issue to me until DJI recommends watching the KV-index in the Mavic manual or a bunch of DJI aircraft fail on the same day when the KV-index is high. One DJI employee mentioning it in a forum really doesn't mean much without evidence that it has caused issues in the past.DJI-Ken posted this just yesterday
Hello all,
Before all I do feel for everyone loosing a drone. It is very dissapointing to say the least. With the owner all due respect and all those with immense drone experience, this are my two cents.
I can understand many times our excitement can get us to overlook important steps. Due diligence is always a must.
Regardless what you fly, there is always a self training period required when one flies the first time and more important under new platforms. The Editors feedback is right on!!
First, read instruction fully. Some people assume because one think that flying a drone previously give you confidence. That is correct and is useful. Yet, one should treat any drone as its first even if you are flaying a replacement.
Second, Never assume or underestimate this device.
One should first get totally familiar previously to do complicated and electronically challenged fly paths. Go to a park a be conservative on your flight. Observe closely drone behavior and response.
Third, like In any critical activity, practice your 3Rs : React, Response, Regain control. Due your due diligence ALWAYS. Zero tolerance on missing any pre-flight steps. Try possible scenarios and practice how to control, and get yourself out of it. Panic can easely take over and delay our response. Practice as much as you can. By doing so under a control path and environmet, it will definetly make the difference when you out there, and the unexpected happens. Then you will be much more responsive, make quick assessment in what to do to bring back your drone safely. This is not a guaranty but isn't will be most helpful indeed.
Kind regards.
Hello all,
Kind regards.
