Rnl
- Joined
- Jan 26, 2017
- Messages
- 1,482
- Reactions
- 659
- Age
- 59
Rite now drop down to 50 or 100 for pic. Now how many bars??
Sent from my VS986 using MavicPilots mobile app
So what was your informed purchasing decision on buying the Mavic pro? was it the so claimed 4.3 mile range? your not going to get that
range unless you live on a beach or a desert. so in reality you must
test your range in real life circumstances, rather then paper back
mislead information..... these 9dbi yagi antennas I bought for my Mavic
do work very well...and made a very big gain on distance...
My informed purchasing decision was a lot of information from DJI, they did publish their specs funnily enough, and yes they even state themselves that's best case scenario. I also watched people on YouTube fly those distances with stock antennas. Of course those tiny little plastic antennas aren't going to be the 'best' setup. And what do you even mean paperback 'mislead' information.... people HAVE flown that far. It also depends if you're in FCC or CE mode and that is determined by your physical location in the world. That's well documented and I've discussed it with DJI support. North America = FCC, rest of world = CE mode.
You want a misleading statement? Here's one and I quote: "
do work very well...and made a very big gain on distance..."
No actual facts there mate. You didn't even say how much? Maybe you should sell antennas too?
i tested some ear reflectors today and just with those i can get 3 bars more hovering 1 mile away blocked by trees.
I have several locations i am going to test with each setup stock, with ears and with yagi and see how much difference it will make.
Ok, I just flew 10 mins ago.... here's the bonus..
I flew from inside my house from sitting at my kitchen island, just from a small window
pointing my radio ....WOW!!!!!!!!!!!!!!View attachment 7252 View attachment 7253
That's pretty good. Are the antenna connectors standard SMA? At least then you could easily swap Yagi's and other types of antenna (e.g. 2.4Ghz whip antenna) for different situations.
I wonder how the sma connectors will do getting removed and put back on over and over a 1000 times.
Might be a good idea to add a quick connector, where you just press on the antenna rather than having to screw on the threads everytime. Could just put a quick connector between. Perhaps the connection wouldn't be as good?
I also had issues with the latest firmware on feb 14, I rolled mine back. I did just buy an iPad mini 2 with cell off Craigslist (new sealed in box) for $200, but that's for a bigger screen. Looking for a good mount now, I don't like the balance in the controller brackets. Just a warning, all iPads have magnets, some say a smart watch has caused compass issues. Just make sure the magnet side is furthest away from the controller. Or maybe even calibrate the IMU, compass, and controller with the iPad in place. That's what I plan to do once I get the mount. Escecialy the controller since it has Hall effect sensors for the sticks.There were no trees. Wide open ground. I agree I could've gone higher. Was at 50m out to that point but rose to 80 to give better clearance and signal but it was still dodgy. Decided to turn around and come home.
The Mavic was hovering about 400m away after flying back and had the app disconnect and wouldn't reconnect. Hit RTH to get it home although ATTI would've been fine. I'm not happy with the number of disconnects under Marshmallow on my Moto Z Play. I might have to get an iPad. Did you feel the earth quake and the disturbance in the Force when I said that?
How about a picture of the full battery adapter?Here it is guys......5 miles out and 5 miles back ...no radio or transmission loss
full bars AND I live in NJ most dense wifi populated area....antennas db pulling
50 -52 db!!!! WOW
Hi Jkantiques please can you post some photos of the battery mod.Ok, I just flew 10 mins ago.... here's the bonus..
Have you got any of how it's installed?
