Mavic pro, Bottom sensors not as good as phantom 3 advanced???
Discussion in 'Mavic Pro Discussions' started by Incogneito, Nov 1, 2016.
  1. Incogneito
    Incogneito Well-Known Member
    Oct 12, 2016
    60
    16
    I was wondering when flying my dad's phantom 3 advanced and even my previously owned phnatom 3 professional, when following any terrain (despite not having terraian follow) the phantom 3 advanced and the phnatom 3 pro will follow up the terrain, and follow down the terrain at a steady altitude. I have tested it on both when I read that the Mavic pro will not follow downhill. That said, the P3A and the P3P does follow the terrain when there is an incline, with no adjustments to altitude, and not having to switch to terrain follow. It even works in the dark as well on both the P3A and The P3P. That was a main reason for my getting my dad the P3A as the P3S does not do it at all during my testing, as it has no bottom sensors. Why was that taken out of the Mavic Pro altogether? I does not follow any terrain at all, while the P3A and the P3P does, even without terrain follow. The terrain follow on the mavic pro also does not follow terrain downhill, only uphill. I tested the Mavic at rather slow speeds and it never gains or loses altitude when the elevation of the ground changes. Both the P3A and the P3P do change altitude accordingly, even at a considerably fast pace. Why does the mavic not follow this same terrain increase and decrease in altitude at 10 or so feet from the ground?
  2. gryphon1911
    gryphon1911 New Member
    Oct 31, 2016
    1
    1
    Does the intelligent flight mode "TERRAIN" not do what you want?
    John Locke likes this.
  3. DesertWindAero
    DesertWindAero Well-Known Member
    Oct 12, 2016
    133
    60
    Mavic literature and YouTube videos indicate Terrain Follow mode is available with settings from 1m to 10m.
  4. Incogneito
    Oct 12, 2016
    60
    16
    What I'm saying though is that the phantom 3 pro and advanced both follow the ground, increasing and decreasing altitude at 10 feet or so, even without a terrain follow mode. They do it automatically. The mavic only follows when terrain follow is on and only increases altitude. It doesn't do it automatically like the phantoms do.
  5. Butterpuff 6
    Butterpuff 6 Well-Known Member
    Oct 16, 2016
    156
    95
    Charlotte, North Carolina
    If I understand you correctly, I don't think my Phantom 4 does that, and I'm glad. It seems like that would lead to some dizzying video if it was constantly going up and down with the terrain. I think if you are real close to the ground it's supposed to keep you from crashing into it, but I've never trusted it enough to really test it.
    gryphon1911 likes this.
  6. Incogneito
    Oct 12, 2016
    60
    16
    I'll have to post a video on youtube.
  7. Mad_Angler1
    Mad_Angler1 Well-Known Member
    Oct 16, 2016
    135
    70
    Wales UK
    P3 did this generally at low level, P4. Did not, DJI never officially announced it at a feature but if you tried to fly a P3 off a bank at low level it would follow it down.
    Just one of those things or did with the vps
  8. Incogneito
    Oct 12, 2016
    60
    16
    YOU GET IT!!!! Finally someone that understands. Well for the most part at least. It also followed uphill as well as downhill, even in low light. So why does the mavic not do the same, regardless of light, or at all for that matter? I tested the phantom 3 advanced at night on my road, it goes up, then level, then up again and the phantom 3 advanced follows it through all elevations, both up and down also at night. The mavic does not follow it at all UNLESS the terrain follow is on, also only during the day only, and ONLY increases altitude, never decreases with the ground under it. The phantom does not have terrain follow, but follows the ground perfectly up and down automatically. I'm just wondering why the mavic doesn't do the same?
    #8 Incogneito, Nov 1, 2016
  9. kmaluo
    kmaluo Well-Known Member
    Oct 14, 2016
    423
    121
    Sounds like a simple software update issue if what you say is true.
  10. Butterpuff 6
    Oct 16, 2016
    156
    95
    I can see how that would be useful sometimes, but I wouldn't want it to be on by default. An option to turn such a feature on when you need it would be good.
  11. TheLightSpeed!
    TheLightSpeed! Well-Known Member
    Oct 12, 2016
    705
    313
    Do you even have a Mavic? I would so before making unsubstantiated statements like this.
    Mine I believes does both up and down? Have to check before I speak.
  12. Incogneito
    Oct 12, 2016
    60
    16
    yes i do have a mavic pro, and a phantom 3 advanced. i have tested it and it works automatically on the advanced, but the mavic would fly into the ground if not giving it a raise altitude or decrease altitude command. Just wondering why this isn't built into the mavic pro automatically as it is with the phantom 3 advanced and the phantom 3 pro as well?
    #12 Incogneito, Nov 1, 2016
  13. NickRno77
    NickRno77 Well-Known Member
    Nov 21, 2016
    55
    14
    Hertfordshire, UK
Loading...
Similar Threads - Mavic pro Bottom Forum Date
Mavic Pro Bottom Board Chip Set Revealed Mavic Pro Discussions Feb 26, 2017
Mavic Pro auto take off height 15+ feet vs 4ft Mavic Pro Help Today at 4:03 AM
Mavic Pro in Nepal - any advice on regulations? sUAV Rules & Regulations Yesterday at 6:52 PM
New firmware for Mavic Pro has been released ( Firmware : v01.03.0700 ) Mavic Pro Discussions Yesterday at 3:39 PM
iPad Pro with Mavic controller General Discussions Yesterday at 3:18 PM
Share This Page
