Used the DJI GoHave you only used the DJI Go 4 app, or was the DJI Go 3 also installed. IF you've had both installed (even if you've uninstalled ver 3) the file structure on your phone will be different.
Called Verizon? Set home lock? Didn't look for the craft, only 800' away? He was too panicked to search? He says "I just wanted to share this"? Says multiple times "total loss". Has flown P3 craft before and never uploaded a .txt flight record, really?
Says he understands English but it's not apparent in his grammar. His flight records disappear? Accuses DJI if erasing them?
What are we suppose to think?
This scores about 9 on the troll scale of probability.
Fly often, be safe
C'mon guys... if you think this is a troll, back off and move along. There's no reason why he needs to be interrogated. Even IF he is a troll, by publicly challenging him, it intimidates other users who may be on the fence asking for help. English clearly isn't his native tongue, and if something doesn't make sense or seems implausible, then perhaps it's just his difficulty in explaining it properly. Getting negative and trying to prove why the guy isn't legit does more harm than good. /steps off soapbox.
I'm trying to decide whether I should get a tracker or not. I've been looking at the Marco Polo and the Trackimo. I'll be flying mostly over wooded country. Marco Polo seems limited in range but otherwise good. The trackimo seems like a good system for range but I'm getting unclear info as to the GPS vs 2G vs 3G versions. How good is the $99 GPS version? I'm ok with the $5/mth fee after the first year but don't want to get into a cellular plan.. . . and a tracker. Having had 2 DJIs fly away, I now have GPS or Marco Polo trackers on everything I fly.
While this is baffling, let's not assume that the OP is trolling.
It's easier to assume that the multiple simultaneous points of failure (fly away, los of logs, etc.) are due in part to user error. Maybe he panicked and did some resets on the app thinking it would "fix" things, and instead he wiped out the data. Of course he isn't likely to admit it here (maybe doesn't even know he did something to wipe it out).
The OP seems to think everything is in the cloud. It is not.
I find it highly coincidental that simultaneous failures to unrelated software/hardware happened. That said, with thousands of users, it's going to happen to someone, somehow, someday.
The frustration here is the inability of the OP to calmly follow instructions and respond with clear and coherent answers. I've worked in Customer Support for a software company 20+ years ago, and you cannot help someone if they cannot clearly communicate the problem nor follow clear instructions and respond back clearly as well.
Patience is key, or in the case of a public forum, "opting out" of trying to assist instead of fanning any flames.
If the OP is as you say genuine then the OP needs to go to the DJI forums and post there - they have DJI staff on there who will help him.
I've posted as few times on the DJI forums and the staff are generally quite helpful and will do their best to solve his issue.
If the OP is genuine and followed all the steps he said he did then that would suggest a serious issue with the Mavic - or at least his Mavic. A few minor mistakes should not lead to a fly away.
Anyway he has yet to provide a single bit of info that suggests he is genuine - but perhaps you could contact him directly and talk him through how to download the logs off his phone.
Personally I think troll but happy to proved wrong with a log file for all to see.
To anyone reading this who is concerned the Mavic suffers fly aways I would just ignore this whole thread. With the current firmware I see no fly away issues. Not to say the next firmware might not create some but as things stand right now the Mavic works well.
Wow, this is baffling, in every possible kind of way.
So the drone (didn't RTH), remote (dropped instantly from full to 30%), and app (wiped all of your logs) all malfunctioned at the same time?
Hi Pablo, I just want to share my information of what had happened to my Mavic.Wow, this is baffling, in every possible kind of way.
Thanks to all drone pilots on this site.I don't know if anyone mentioned it to you yet and getting helpful information after your Mavic has flown away is bittersweet
But,;
1. I called State Farm Insurance and got the drone covered for any type of loss.....35.00 a year no detuctable
2. Install a TRACKIMO GPS locator. You'll find it every time.....unless it's in the drink.
Their server was down again early this morning.Are you claiming that DJI deliberately erased you flight data? For what reason? Did you have DJI Care on the Mavic?
I'm pretty sure he's not trolling-- I actually experienced a similar problem last week-- I barely got it back to the beach. -- I was flying along the water following a speedboat at 66kmph in FPV (using litchi). I didn't notice the boat had turned, leading me to the far side of an island and I lost signal. As expected the mavic started the RTH procedure rising to 50M... I walked along the beach trying to regain line of sight with the drone and occaisionally got a video feed update. I finally regained control of the drone when my battery was down to 46% and it was now at 130meters in altitude and not moving forward (toward me) at all-- speed 0kmph. I cancelled the RTH and tried to fly it toward me but the screen said there was an obstacle (the drone was atleast 100meters above any obstacle at this point). The drone refused to move forward due to obstacle avoidance so I switched it to Sport mode and then was able to fly it back. I got it down with only 14% battery remaining. -- Have any of you had similar obstacle avoidance glitches where the drone keeps rising to try RTH? I checked the front facing cameras and they looked clean.This sounds like trolling
Check out this incident which is similar. It's a long thread. The summary is that it was an RTH that climbed instead of returning. Probably because it was facing a low sun and the OA thought it was an obstacle.I'm pretty sure he's not trolling-- I actually experienced a similar problem last week-- I barely got it back to the beach. -- I was flying along the water following a speedboat at 66kmph in FPV (using litchi). I didn't notice the boat had turned, leading me to the far side of an island and I lost signal. As expected the mavic started the RTH procedure rising to 50M... I walked along the beach trying to regain line of sight with the drone and occaisionally got a video feed update. I finally regained control of the drone when my battery was down to 46% and it was now at 130meters in altitude and not moving forward (toward me) at all-- speed 0kmph. I cancelled the RTH and tried to fly it toward me but the screen said there was an obstacle (the drone was atleast 100meters above any obstacle at this point). The drone refused to move forward due to obstacle avoidance so I switched it to Sport mode and then was able to fly it back. I got it down with only 14% battery remaining. -- Have any of you had similar obstacle avoidance glitches where the drone keeps rising to try RTH? I checked the front facing cameras and they looked clean.
At this point, it sure is tempting to disable all obstacle avoidance sensors..
I always disable it with Litchi WPT missions. In your situation had you spun the drone 180 degrees and flown backwards you should have been able to defeat it...
Will do, with my second Mavic.Flying into low sun triggers obstacle detection. If you know you're in the clear, turn off forward OA.
where did you mount the Marco Polo on your Mavic? Sounds interesting?. . . and a tracker. Having had 2 DJIs fly away, I now have GPS or Marco Polo trackers on everything I fly.
You can find some commonly used Marco Polo tracker mounting locations in this thread.where did you mount the Marco Polo on your Mavic?
