Without the drone in front of me (I'm at work), is this feature available on the Mavic yet?
There is "Tap Fly", but I don't know what "Reverse Tap Fly" is. Could you explain?Without the drone in front of me (I'm at work), is this feature available on the Mavic yet?
The better option might be "course lock" that way the Mavics orientation can be changed to suit while flying on a straight line, you would have to keep an eye on elevation though, as that remains the same as when the mode is enabled, but is adjustable in flight!
Hope this helps?
You can also do it, to some extent, using Active Track. Although horizontal speed control seems to be limited to about 3-4kph (not counting if the Mavic is actually following a subject).
