Does anyone recommend or have any kind of tracking device
out there such as trackimo?
Sent from my XT1254 using MavicPilots mobile app
I use a Marco Polo attached to the side of the body with Velcro. Holds fast, small and discrete, great range and reasonable price (as far as I'm concerned).
Anyone tried the TK-Star GPS tracker. Just got one, not tried it yet on the Mavic but testing the accuracy it is very accurate, to within 3ft surprisingly. Going to velcro it to the side, hopefully it wont't fall off but I should be able to find it if it does
It is gprs and GPS. I am a little worried about the gprs causing interference so will take it easy and stay close whilst monitoring signal. You can set the sleep timer on it so I am hoping that whilst sleeping it isn't broadcasting anything, you wake it up by calling it so I'll check the signal whilst sleeping and then wake it up and see if the signal is degraded.
Looked at the Marco Polo initially but as said not available in the UK. Also quite heavy at 90g, 4x the Marco Polo.
Photo of it?I use a Marco Polo attached to the side of the body with Velcro. Holds fast, small and discrete, great range and reasonable price (as far as I'm concerned).
when the legs are extended for flight your tracker antennae is real close to the drones antennae.putting the tracker on a rear leg is better.Got my Marco Polo today and mounted it here.
