mavic video quality problems
Discussion in 'Photos and Videos' started by Fattybolatty, Nov 19, 2016.
  1. Fattybolatty
    Fattybolatty Member
    Nov 19, 2016
    16
    1
    Hi,just got my mavic a few days ago and have flown it a couple of times. on reviewing the video footage it seems of very poor quality and I'm getting a king of ripple effect especially anything that is white in colour.
    Yes i have done the tap to focus before filming.
    filming 1080p 50fps
    all other settings are standard.
    updated firmware and calibrated imu before first use. Any ideas?
    i will try and get a video clip to show what it looks like.
  2. Fattybolatty
    Fattybolatty Member
    Nov 19, 2016
    16
    1
    here is a vid, if you look at the front of the buildings on the right you will see them flicker as if there is a diagonal stripe running across them.
    Any help would be appreciated.
    [​IMG]
  3. 4wd
    4wd Well-Known Member
    Oct 12, 2016
    884
    321
    North York Moors
    There are several threads about rather poor performance at 1080p unless you use 30fps or less.
    It's a feature not a fault - just not a very useful feature.
  4. fafa20
    fafa20 Member
    Oct 15, 2016
    8
    2
    I noticed the same problem in 1080p personally I film in 4k the quality is much better and I reduce in 1080p assembly
  5. Lightsout
    Lightsout Well-Known Member
    Oct 15, 2016
    159
    55
    Here is 4K reduced to 1080p
    simplyRik likes this.
  6. Todd Reimer
    Todd Reimer Active Member
    Oct 16, 2016
    34
    11
    The issue with the buildings is a common issue called 'aliasing'. Your Mavic isn't broke. As others have mentioned, shooting in 4k and downsampling to 1080P may help in some instances. Otherwise, google around and enjoy spending many hours getting up to speed on this topic. (It's good info to know)
  7. ElGuapo
    ElGuapo Well-Known Member
    Dec 1, 2016
    290
    113
    Burbank, CA
    If you are going to shoot at 50 fps you need a filter and switch to manual settings. Otherwise stay at 30 fps
  8. MaineRC
    MaineRC Member
    Nov 27, 2016
    5
    5
    isn't this just "jello", which would be cured by using a ND filter which will be available soon; it's because the shutter speed is too high.
  9. Kilrah
    Kilrah Well-Known Member
    Nov 12, 2016
    1,865
    741
    Switzerland
    No, it's the aliasing caused by the crude resize process used for >30fps framerates due to insufficient processing power to do it better (as we've been told by DJI reps).
    And jello is not "cured" by an ND filter, it's turned into a less distracting blur but that's not desirable either.
  10. Bineet
    Bineet New Member
    Dec 16, 2016
    3
    Hi All,
    I recently got my Mavic Pro and flown it a few times. I am seeing terrible noise/grains in the video and aliaising effect even when shooting at 4K, 25 fps. I used the stock settings. Wondering if I have a broken piece or need to do something with the settings/firmware/DJI app etc.? Any help would be much appreciated.
    P.S: I am running the latest firmware.
  11. Bineet
    Bineet New Member
    Dec 16, 2016
    3
    Here's the night video...lot of noise. Again, I am very new to this entire system, please advise as to what am I missing here.
  12. 4wd
    Oct 12, 2016
    884
    321
    North York Moors
    Considering the low light (first video) I don't think that's too bad, it is trying very hard to make it contrasty with bright colours - which doesn't work too well at dusk.
    The only decent night footage I've seen is from very brightly lit city centres.
    You need to try more 'normal' light conditions and turning the custom settings to all -1 is going to improve things.
  13. Bineet
    Bineet New Member
    Dec 16, 2016
    3
    Thanks. I used to have P4 before I returned it for Mavic. Since I didn't observe such noise in low light settings for that, I was a little taken by surprise. Also, youtube's processing has made the video a little softer; the raw footage looks lot more grainy.
    Anyway, I think as long as the video quality issues I am seeing in daylight at 4K are not there, I would be happy. I will try the proposed settings.
    #13 Bineet, Dec 19, 2016
  14. wiznz
    wiznz New Member
    Apr 27, 2017
    2
    I have the same issue, i am running it at 4k 25fps, it's noticeable in this setting especially white objects. Is this something that can be adjusted in software or a Mavic firmware update?
Loading...
Similar Threads - mavic video quality Forum Date
Mavic Pro using Litchi Very poor uplinked video quality Control Apps - DJI, Litchi, Autopilot, etc... Apr 5, 2017
First Mavic video, after comments on video quality /water colour effect Photos and Videos Mar 12, 2017
Brand new never flown Mavic with video issues Mavic Pro Help Yesterday at 10:16 PM
How Should I Export Mavic Video From Final Cut? Mavic Pro Discussions Sunday at 10:04 AM
Mavic Pro - Motocross Short Video Photos and Videos Saturday at 6:23 PM
Share This Page
