ElGuapo
flyNfrank - I am running the fw the aircraft came with and have been using Auto TakeOff (40 flights using ATO), no issues whatsoever to report.
I didn't say I have had auto-takeoff issues on the Mavic, I haven't, but the possibility of motor shut off is a concern, my Mother didn't raise a slow kid, seems yours raised a wise guy. And don't put words in my mouth, I never said I had never heard of F/W issues with the P3, only that I never had any, you sound like a politician, making up stuff as you go.And to think you never experienced or heard of firmware issues with your now 2yr old P3. Dang it....you were on a streak too....
Sit down and relax, nobody calling you names. Btw, other post you acted as if you never heard of issues on the P3. Nuff said.I didn't say I have had auto-takeoff issues on the Mavic, I haven't, but the possibility of motor shut off is a concern, my Mother didn't raise a slow kid, seems yours raised a wise guy. And don't put words in my mouth, I never said I had never heard of F/W issues with the P3, only that I never had any, you sound like a politician, making up stuff as you go.
Just started looking. Not saying it's a problem at this point, but one thing that jumped out right away was this flight started with 35% battery. 11.17 volts and dropped to 11.00 volts.
Yeah, This was at the end of a longer flight, started at 100%, wanted to try out auto take off before I went home. Not like I was about to go for a huge sport mode flight. Also, thats just under the nominal lipo battery voltage, should easily be able to lift off and hover. I wonder if this is more of a battery issue than a mavic issue?
Just so you know, I'm not saying you did anything wrong. I do know that one of the 1st things the techs look at when researching is if the flight starts with the DJI Recommended 100% full charge in the battery. Just so you know a head of time, in case of a warranty claim you may get something like..."of course it did because the battery wasn't near or fully charged".
On the flipside...I doubt this has to do with the battery unless, 11.00 and under is a red flag? I looked at a few other mavic files I have which both started with full battery which were well into the 12 volt range and they never were even close to 11.00 volts. I'll admit the mavic setup is new to me and I don't know what is and is not good, yet.
Has this been narrowed down to a particular version of the software? I just installed the recent 12/26 update but have not flown yet.
Ok the next thing to stand out is....data says the IOC was unable to work, and it never registered the A/C off the ground.
Less the 1 second after it began liftoff it recognized a problem that displayed a disruption throughout several other areas of data.
Thanks, appreciate your help. The DJI go app also said I was well within the green time bar, and I think I had at least 5mins of flying remaining. I think if I was in the yellow or red they could say something, but I was in the green...
Others in this thread are reporting the ATO bug/issue after updating to ver v01.03.0000 - the latest at the time. It is not clear if the bug was present prior to the update. However DJI quickly released v01.03.0200, no word in the documentation if it contains the fix for bugs created by the previous update.
I need the DAT to see what is more detailed data then the TXT. Let me try to explain one huge issue here that many do not know about. I know this can be explained better but, when the A/C Ascends at anytime it uses almost the most battery resources during that process. While in this process available voltage drops. Depending on the "overall" amount of battery volts the battery has, this process can actually drain down the battery below what is a "safe limit". If at any point you stop the process, such as climbing higher, the battery has what is called "recovery volts" meaning the volts will begin returning back near that starting voltage point.
So.....if you start off with a low battery from the beginning of a flight, and in cold weather temps, it will take no time for the "usable volts" to reach that point of "safe voltage". Btw, the safe voltage point is dictated by what the developer has set in the firmware.
What I say to others is, do not make the mistake of thinking is going to operate the way you think it should. Don't take it for granted. When it come to battery anything.....DJI has always been pretty adamant about fully charged batteries prior to takeoff.
Cool thanks for the explanation. So say you take off with 100%, fly around for 10mins, decide to land with 55% because you want to move to a different location. That battery is done? You need to charge it to 100% before taking off again? What about another scenario, you take off with 100% and do a big flight, you are coming home with 35% and need to ascend to get above an obstacle, will the mavic drop from the sky because the battery voltage dropped?
