New Design for Lens Hood
Discussion in 'Mavic Pro Discussions' started by stealle, Dec 29, 2016.
  1. stealle
    stealle Well-Known Member
    Oct 12, 2016
    290
    153
    I think its great we have a DIY option for making our own lens hood. We can even buy one now on ebay with the SAME design. There are also a few others like Taco-RC that will have the SAME design available soon. I'm just wondering if anyone else is interested in a different design. One that would still attach the same way as the dome, but would flare out a little more to resemble the shape of a regular lens hood. I understand you can't have much on the bottom for when the gimble points down. I'm talking about mostly on the right and left sides. The current offering does a good job of blocking light when the sun is on the right side of the Mavic, but there is less material on the left side that doesn't block as much light when the sun is on the left side of the Mavic.
    I don't have a 3d printer. I'm not certain it's possible, but it seems to me that the design could deviate somewhat from the dome shape and provide better coverage.
  2. LakeTravis
    LakeTravis Well-Known Member
    Oct 15, 2016
    324
    198
    Austin, TX
    I just ordered one of the Mavic Lens Hood Sun Shades from eBay. Hope it helps!!
    Christopher G. Hughes likes this.
  3. leenanj
    leenanj Well-Known Member
    Oct 13, 2016
    56
    36
    Been working on my own design just making it smaller and lighter
    with minimal supports needed, I hate supports when printing.
    I am leaving the bottom open.
    This is what I have so far.
  4. LakeTravis
    Oct 15, 2016
    324
    198
    Austin, TX
    Don't you think a flat black color would be better? Seems like the orange might throw off a bit of a colored reflection? Not really sure myself.
  5. leenanj
    Oct 13, 2016
    56
    36
    Yes for sure a darker color, just making some prototype's with this color because I have a lot of it.
    The final with probably be gun metal grey that matches the Mavic.
    RAFALE and Nathan Hoover like this.
  6. Petomaster
    Petomaster Member
    Nov 23, 2016
    13
    3
    it sure does. Just look at the orange reflection on the lens.
    Nice job, but spray that baby matte black.
    SeaFox likes this.
  7. DVegaman
    DVegaman Member
    Dec 12, 2016
    24
    6
    NJ
    What material are you printing that in? Looks good.
  8. BradBuskey
    BradBuskey Well-Known Member
    Dec 25, 2016
    56
    25
    Louisville, KY
    Outer color can be whatever, however you should treat the inside with matte black. There is a reason why the inner surface is matte black on standard lens hoods.
  9. LakeTravis
    Oct 15, 2016
    324
    198
    Austin, TX
    Makes sense.
  10. Filmscum
    Filmscum Well-Known Member
    Dec 26, 2016
    37
    Cody, WY
    Nice design, will you be posting the file on Thingiverse by chance?
  11. dontfeedthenerd
    Dec 22, 2016
    20
    6
    Second on posting the file on Thingiverse!
  12. stealle
    Oct 12, 2016
    290
    153
    That looks pretty good. Does the left side (the Mavic's left side) come out as far as the right side? Basically, what I'm saying is. It seems like the best design would provide maximum coverage without causing any vignetting. It seems like people are sticking to the design that looks like just cutting a hole out of the dome when it could look more like the photo below only with 3 sides (bottom would need to be missing). And, obviously the design would have to mount the same way as the dome.
    [​IMG]
  13. leenanj
    Oct 13, 2016
    56
    36
  14. CactusJackSlade
    CactusJackSlade Well-Known Member
    Oct 17, 2016
    349
    113
  15. SLVSRFR
    SLVSRFR Well-Known Member
    Dec 22, 2016
    49
    25
    Thanks for sharing! Printing it in carbon fiber proto pasta as I type!
  16. Filmscum
    Dec 26, 2016
    37
    Cody, WY
  17. halley
    halley Well-Known Member
    Nov 27, 2016
    677
    365
    Central Honshu, Japan
    A frustrum hood like the one you show is geared to move with the lens. The gimbal has to move, so the range has to be even wider than this example and the rear opening has to be pretty large to avoid the camera's movement at the end of the gimbal. Also, the gimbal itself is not symmetrical, with the first axis on the ship's right side. The original cover has extra space on that side.
  18. Anthony Viscomi
    Anthony Viscomi Well-Known Member
    Oct 12, 2016
    887
    336
    Philadelphia, PA
    Little "off topic"...but what Brand/Model of 3D printers are you all using?
  19. leenanj
    Oct 13, 2016
    56
    36
    Sounds like you have a top end 3D printer.
    Would love to see a picture of the final product.
  20. LakeTravis
    Oct 15, 2016
    324
    198
    Austin, TX
    OK, I am pretty technical, but I have to admit (as Grandma used to say), "you couldn't fill a thimble with all I know about" 3D Printing... Trust me, that was one of the more socially acceptable things she used to say. I was just curious to know if you can use fine grit sandpaper and carefully smooth out the ridges on things like this after they've been printed?
Loading...
Similar Threads - Design Lens Hood Forum Date
Gimbal design and pictures Mavic Pro Discussions Feb 12, 2017
New Mavic Pro Case Design - Suggestions Welcome Mavic Pro Discussions Jan 30, 2017
Custom Vinyl Design Giveaway Mavic Pro Discussions Jan 11, 2017
Shirt design help Mavic Pro Discussions Jan 10, 2017
Mavic Remote Control Design General Discussions Jan 7, 2017
Share This Page
